question regarding device.changed
Posted: Saturday 27 April 2019 19:10
by Gravityz
i need to theck on a device to see if it has changed.
i currently have a script which is triggered by a device.
so if the device goes from OFF to ON it triggers the script but also when going from ON to OFF
The problem however is that this script is also trigggered when the device goes from ON to ON (device is triggered from another script but it was already on)
so i either need to chreck it's previous state(and i do not want to use anotrher virtual switch
Question: will device. changed work for this?
Eg, will this ony be set to true if the device goes from ON to OFF and OFF to ON (the device has changed) but will it be false when it goes from ON to ON or OFF to OFF(the device is triggered but the state has not changed)
.checkFirst will not work in my case because i have also other devices which need to react on this change
thanks
Re: question regarding device.changed
Posted: Saturday 27 April 2019 21:15
by waaren
Gravityz wrote: Saturday 27 April 2019 19:10 So i either need to chreck it's previous state(and i do not want to use anotrher virtual switch
No
Eg, will this only be set to true if the device goes from ON to OFF and OFF to ON (the device has changed) but will it be false when it goes from ON to ON or OFF to OFF(the device is triggered but the state has not changed)
To do this you will have to safe previous state somewhere. My preference would be to do this using a dzVents persistent variable like.
            on =    {
                      devices = { 1886 },
    data =  {
                lastState = { initial = "" }
    execute = function(dz, item)
        if item.state ~= dz.data.lastState then
            print("device " .. item.name .. " has changed state to " .. item.state)
            dz.data.lastState = item.state
            print("device " ..  item.name .. " has kept state " .. item.state)
Posted: Sunday 28 April 2019 9:33
by Gravityz
thanks, will try it.
at first i wanted to skip double on messages only but it might be better to skip double messages totally.
will this work? especially the " if (checkParms() and LastStatus ~= Line) "
-- this scripts holds all the globally persistent variables and helper functions
-- see the documentation in the wiki
-- NOTE:
-- THERE CAN BE ONLY ONE global_data SCRIPT in your Domoticz install.
-- global persistent data
data = {
LastStatus = { initial = "" }
-- global helper functions
helpers = {
addRollingTextLine = function(domoticz, textDevice, line, maxLines)
-- code
local time=domoticz.time.rawTime
time=time..' -- '
local function stringSplit(str)
local lines = {}
for s in str:gmatch("[^\r\n]+") do
table.insert(lines, s)
return lines
local function checkParms()
if not textDevice or ( type(textDevice) ~= "string" and type(textDevice) ~= "table" ) then
domoticz.log("textDevice should be of type table or string; now: " .. (tostring(textDevice) or type(textDevice)),domoticz.LOG_ERROR)
return false
elseif type(textDevice) == "string" then
textDevice = domoticz.devices(textDevice)
if not line then
domoticz.log("No text supplied",domoticz.LOG_ERROR)
return false
if not maxLines then maxLines = 5 end -- default
return true
if (checkParms() and LastStatus ~= Line) then
local lines = textDevice.text or ""
lines = stringSplit(lines)
line=time..line
lines[0] = line
local newText = ""
for i = 0, ( maxLines - 1) do
newText = newText .. ( lines or "" ) .. "\r\n"
textDevice.updateText(newText)
LastStatus = Line
return false
Posted: Sunday 28 April 2019 11:15
by waaren
Gravityz wrote: Sunday 28 April 2019 9:33 at first i wanted to skip double on messages only but it might be better to skip double messages totally.
I don't understand what you ask in relation to the topic.
And please use code tags when posting code.
You can "tag" your code by typing
around your code. (use the </> button in the forum editor
Posted: Sunday 28 April 2019 12:28
by Gravityz
My mistake.
thought i used code but i used text !!!!
question is simple.
will this check work
checkparms() (which is a function) will return TRUE or FALSE
LastStatus ~= Line (which both are strings) will return TRUE or FALSE
but i do not know if i can combine the outcome of a function with a compare
here is the complete code
-- NOTE:
    data = {
	helpers = {
			-- code
                time=time..' -- '
                local lines = {}
                return lines
                    return false
                if not line then
                    return false
                return true
                line=time..line
                lines[0] = line
                local newText = ""
                    newText = newText ..  ( lines[i] or "" ) .. "\r\n"
                LastStatus = Line
                return false
Re: question regarding device.changed  [Solved]
Posted: Sunday 28 April 2019 12:59
by waaren
Gravityz wrote: Sunday 28 April 2019 12:28 question is simple. will this check work
Yes that is possible. If the function returns anything different then false or nil it will be considered true.
Posted: Sunday 28 April 2019 13:11
by Gravityz
thanks
Posted: Monday 29 April 2019 19:38
by Gravityz
Hmmmmmm
still not working.
it seems that the LastStatus string can not be compared with the line string.
if i simply do
if LastStatus ~= line then
it does not seem to work
i printed out both strings in the log and they look exactly the same
could it be that the variables are somehow not the same type (string) and therefor can not be compared
Posted: Monday 29 April 2019 19:57
by waaren
Gravityz wrote: Monday 29 April 2019 19:38 it seems that the LastStatus string can not be compared with the line string.
Not if the print looks the same.
Can you please share your complete script and global_data.lua. If you do not want to do this here then via PM is also OK
Posted: Monday 29 April 2019 20:09
by Gravityz
lux script which call global_data helper function but the idea is that if global_data helper gets passed with a string which is the same as the previous one it will not update/rotate the text device.
    active = true,
        timer = {
            'Every 5 minutes between 50 minutes before sunset and sunset'
        if (domoticz.devices('Lux woonkamer').lux  < 17 and domoticz.devices('Woonkamer schedule').state == 'Off') then
            local results = domoticz.helpers.addRollingTextLine(domoticz, 'Status', 'Het is donker, lampen eerder aan', '5')
            domoticz.devices('Woonkamer schedule').switchOn()
so a look at the global_data script should give an idea what is going wrong.
it should work but it is not.
i tried several ways to compare LastStatus with line but they all fail
i have multiple scripts calling the global_data helper but they all parse the data the same way.
global_data
-- NOTE:
    data = {
	    'LastStatus'
	helpers = {
			-- code
                time=time..' -- '
                local lines = {}
                return lines
                    return false
                if not line then
                    return true
                return true
            if (checkParms() and LastStatus ~= line) then
                LastStatus = line
                line=time..line
                lines[0] = line
                local newText = ""
                return false
Posted: Monday 29 April 2019 20:57
by waaren
Gravityz wrote: Monday 29 April 2019 20:09 lux script which call global_data helper function but the idea is that if global_data helper gets passed with a string which is the same as the previous one it will not update/rotate the text device.
Can you please try with this global_data.lua ? I marked the changed lines with -- Changed
-- NOTE:
    data = {
                LastStatus = { initial = "notset" },   -- Changed
	helpers = {
			-- code
                time=time..' -- '
                local lines = {}
                return lines
                    return false
                if not line then
                    return true
                return true
            if (checkParms() and domoticz.globalData.LastStatus ~= line) then   -- Changed
                domoticz.globalData.LastStatus = line   -- Changed
                line=time..line
                lines[0] = line
                local newText = ""
                return false
Posted: Monday 29 April 2019 21:45
by Gravityz
that seems to be working.
thanks, would not have figured this out myself
will let the script run for a day to see if it really does the job
does this mean that a global_data variable has to be used this way in every other script, including the global_data script it is declared in
seems strange, escpecially since the testing was done inside the global_data script and the variable printed from within the script seemed to hold the correct string.
Posted: Monday 29 April 2019 22:33
by waaren
Gravityz wrote: Monday 29 April 2019 21:45 does this mean that a global_data variable has to be used this way in every other script, including the global_data script it is declared in
Yes
Posted: Wednesday 01 May 2019 9:14
by Gravityz
Thanks Waaren
tested it overnight and it works
