Fibaro HC2 hardware
terrorsource
Fibaro HC2 hardware
Post by terrorsource »
I saw that Home Asisstant has integrated Fibaro HC2/HCL support. Don't know if it's only READ or that it can also EXECUTE.
Forum topic: https://forum.fibaro.com/topic/32395-ho ... ro-hclhc2/
Reading a few posts in that topic brought an idea that it should be possible to have Domoticz read/execute in HC2 as well instead.
This way we can use the status/devices from HC2 in Domoticz.
FibaroLink makes it only possible to use Domoticz devices as VirtualDevices in HC2.
Found an API which makes it possible to do that.
If you own a Fibaro HC2 you can use the following url to show the documentation around this API:
http://ipaddress/docs/#!/devices/getDevices
devices : Operations about devices Show/Hide List Operations Expand Operations Raw
GET /devices Get list of available devices
POST /devices Create device
POST /devices Call action
GET /devices/{deviceID} Get device object
PUT /devices/{deviceID} Modify device
DELETE /devices/{deviceID} Delete device
POST /devices/{deviceID}/action/{actionName} Call action
POST /devices/groupAction/{actionName} Call group action
It reads the devices via:
http://ipaddress:80/api/devices
I have 1 sensor (Fibaro Wall Plug) connected to the HC2 and this is the result of the api/devices:
    "id": 1,
    "name": "zwave",
    "roomID": 0,
    "type": "com.fibaro.zwavePrimaryController",
    "baseType": "",
    "enabled": true,
    "visible": false,
    "isPlugin": false,
    "parentId": 0,
    "remoteGatewayId": 0,
    "viewXml": false,
    "configXml": false,
    "interfaces": [
      "zwave"
    "properties": {
      "UIMessageSendTime": "0",
      "autoConfig": "0",
      "configured": true,
      "date": "a",
      "dead": "false",
      "deviceControlType": "0",
      "deviceIcon": "28",
      "disabled": "1",
      "emailNotificationID": "0",
      "emailNotificationType": "0",
      "endPoint": "0",
      "endPointId": "0",
      "log": "",
      "logTemp": "",
      "manufacturer": "",
      "markAsDead": "true",
      "model": "",
      "nodeID": "1",
      "nodeId": "0",
      "parameters": [],
      "parametersTemplate": "0",
      "pollingDeadDevice": "false",
      "pollingTime": "1354829138",
      "pollingTimeNext": "1354837724",
      "pollingTimeSec": 125,
      "productInfo": "",
      "pushNotificationID": "0",
      "pushNotificationType": "0",
      "remoteGatewayId": "0",
      "requestNodeNeighborStat": "0",
      "requestNodeNeighborStatTimeStemp": "",
      "requestNodeNeighborState": "",
      "requestNodeNeighborStateTimeStemp": "",
      "saveLogs": "true",
      "serialNumber": "",
      "showChildren": "1",
      "smsNotificationID": "0",
      "smsNotificationType": "0",
      "status": "STAT_IDLE",
      "sunriseHour": "06:22",
      "sunsetHour": "21:00",
      "useTemplate": "true",
      "userDescription": "",
      "value": "0",
      "zwaveBuildVersion": "3.67",
      "zwaveCompany": "Unknown",
      "zwaveInfo": "",
      "zwaveRegion": "EU",
      "zwaveVersion": "4.33"
    "actions": {
      "pollingDeadDevice": 1,
      "pollingTimeSec": 1,
      "reconfigure": 0,
      "requestNodeNeighborUpdate": 1,
      "turnOff": 0,
      "turnOn": 0
    "created": 1556369518,
    "modified": 1556369518,
    "sortOrder": 1
    "id": 2,
    "name": "emailaddress",
    "roomID": 0,
    "type": "HC_user",
    "baseType": "com.fibaro.voipUser",
    "enabled": true,
    "visible": true,
    "isPlugin": false,
    "parentId": 0,
    "viewXml": false,
    "configXml": false,
    "interfaces": [
      "voip"
    "properties": {
      "Email": "emailaddress",
      "HotelModeRoom": "0",
      "LastPwdChange": "1556369626",
      "Latitude": "xx.xx",
      "Location": "xx:xx",
      "LocationTime": "2012-12-06 12:15",
      "LocationTimestamp": "1354792521",
      "Longitude": "16.84",
      "PreviousLatitude": "xx.xx",
      "PreviousLocation": "5xx;xx",
      "PreviousLocationTime": "2012-12-06 12:14",
      "PreviousLocationTimestamp": "1354792461",
      "PreviousLongitude": "16.84",
      "SendNotifications": "true",
      "TrackUser": "0",
      "UserType": "superuser",
      "atHome": "false",
      "deviceIcon": "91",
      "fidUuid": "",
      "firmwareUpdateLevel": "0",
      "initialWizard": "false",
      "saveLogs": "1",
      "sipDisplayName": "_",
      "sipUserID": "1",
      "sipUserPassword": "",
      "useOptionalArmPin": "false",
      "usePin": "false"
    "actions": {
      "sendEmail": 2,
      "sendPush": 1,
      "setSipDisplayName": 1,
      "setSipUserID": 1,
      "setSipUserPassword": 1
    "sortOrder": 2
    "id": 3,
    "name": "YR Weather",
    "roomID": 0,
    "type": "com.fibaro.yrWeather",
    "baseType": "com.fibaro.weather",
    "enabled": true,
    "visible": true,
    "isPlugin": true,
    "parentId": 0,
    "viewXml": true,
    "configXml": true,
    "interfaces": [],
    "view": [],
    "properties": {
      "ConditionCode": "3200",
      "ConditionCodeConverted": "0",
      "Humidity": "0.00",
      "Pressure": "0.00",
      "Temperature": "0.00",
      "WeatherCondition": "unavailable",
      "Wind": "0.00",
      "categories": "[\"other\"]",
      "dead": "false",
      "deadReason": "",
      "deviceIcon": "28",
      "hidden": "false",
      "log": "",
      "logTemp": "",
      "manufacturer": "",
      "model": "",
      "saveLogs": "true",
      "ui.Current_Weather_Label.caption": "Temp.: 0°C\n\nHumidity: 0%\n\nWind: 0km/h",
      "ui.config.hidden.caption": "This device is hidden in the system.",
      "ui.config.hidden.enabled": true,
      "ui.config.section1.caption": "Configuration",
      "ui.config.section1.enabled": true,
    "actions": {},
    "sortOrder": 3
    "id": 4,
    "name": "4",
    "roomID": 0,
    "type": "com.fibaro.zwaveDevice",
    "baseType": "com.fibaro.device",
    "enabled": true,
    "visible": false,
    "isPlugin": false,
    "parentId": 1,
    "viewXml": false,
    "configXml": false,
    "interfaces": [
      "polling",
      "zwave",
      "zwaveAssociation",
      "zwaveConfiguration",
      "zwaveMultiChannelAssociation",
      "zwaveSlaveRouting"
    "properties": {
      "configured": true,
      "dead": "false",
      "deadReason": "",
      "deviceIcon": "28",
      "deviceSpecificData": "h'000000000000917a",
      "deviceSpecificIdType": "Serial Number",
      "deviceState": "Configured",
      "endPointId": "0",
      "lastWorkingRoute": "[1]",
      "lastWorkingRouteRequestStatus": "ok",
      "lastWorkingRouteRequestTimestamp": "0",
      "lastWorkingRouteResponseTimestamp": "1556381222",
      "log": "",
      "logTemp": "",
      "manufacturer": "",
      "model": "",
      "neighborList": "[1]",
      "neighborListRequestStatus": "ok",
      "neighborListRequestTimestamp": "0",
      "neighborListResponseTimestamp": "1556381222",
      "nodeId": "2",
      "parameters": [
          "id": 1,
          "lastReportedValue": 0,
          "lastSetValue": 0,
          "size": 1,
          "value": 0
          "id": 2,
          "lastReportedValue": 1,
          "lastSetValue": 1,
          "size": 1,
          "value": 1
          "id": 3,
          "lastSetValue": 0,
          "size": 2,
          "value": 0
          "id": 10,
          "lastReportedValue": 80,
          "lastSetValue": 80,
          "size": 1,
          "value": 80
          "id": 11,
          "lastReportedValue": 15,
          "lastSetValue": 15,
          "size": 1,
          "value": 15
          "id": 12,
          "lastReportedValue": 30,
          "lastSetValue": 30,
          "size": 2,
          "value": 30
          "id": 13,
          "lastReportedValue": 10,
          "lastSetValue": 10,
          "size": 2,
          "value": 10
          "id": 14,
          "lastReportedValue": 3600,
          "lastSetValue": 3600,
          "size": 2,
          "value": 3600
          "id": 15,
          "lastSetValue": 0,
          "size": 1,
          "value": 0
          "id": 20,
          "lastSetValue": 0,
          "size": 1,
          "value": 0
          "id": 21,
          "lastReportedValue": 300,
          "lastSetValue": 300,
          "size": 2,
          "value": 300
          "id": 22,
          "lastReportedValue": 500,
          "lastSetValue": 500,
          "size": 2,
          "value": 500
          "id": 23,
          "lastReportedValue": 6,
          "lastSetValue": 6,
          "size": 1,
          "value": 6
          "id": 24,
          "lastReportedValue": 255,
          "lastSetValue": 255,
          "size": 2,
          "value": 255
          "id": 30,
          "lastReportedValue": 63,
          "lastSetValue": 63,
          "size": 1,
          "value": 63
          "id": 31,
          "lastSetValue": 0,
          "size": 1,
          "value": 0
          "id": 32,
          "lastReportedValue": 600,
          "lastSetValue": 600,
          "size": 2,
          "value": 600
          "id": 40,
          "lastReportedValue": 25000,
          "lastSetValue": 25000,
          "size": 2,
          "value": 25000
          "id": 41,
          "lastSetValue": 1,
          "size": 1,
          "value": 1
          "id": 42,
          "lastSetValue": 0,
          "size": 1,
          "value": 0
          "id": 43,
          "lastReportedValue": 2,
          "lastSetValue": 2,
          "size": 1,
          "value": 2
          "id": 50,
          "lastReportedValue": 3,
          "lastSetValue": 3,
          "size": 1,
          "value": 3
      "parametersTemplate": "741",
      "pollingInterval": "0",
      "pollingTimeSec": 0,
      "productInfo": "1,15,6,2,16,1,3,2",
      "saveLogs": "true",
      "serialNumber": "h'000000000000917a",
      "zwaveCompany": "Fibargroup",
      "zwaveInfo": "3,4,5",
      "zwaveSoftwareVersion": "{}",
      "zwaveVersion": "3.2"
    "actions": {
      "getLastWorkingRoute": 0,
      "getNeighborList": 0,
      "getParameter": 1,
      "poll": 0,
      "reconfigure": 0,
      "requestNodeNeighborUpdate": 0,
      "setParameter": 2
    "created": 1556381222,
    "modified": 1556381222,
    "sortOrder": 4
    "id": 5,
    "name": "TestSwitch",
    "roomID": 0,
    "type": "com.fibaro.FGWP102",
    "baseType": "com.fibaro.FGWP",
    "enabled": true,
    "visible": true,
    "isPlugin": false,
    "parentId": 4,
    "viewXml": false,
    "configXml": false,
    "interfaces": [
      "deviceGrouping",
      "energy",
      "fibaroFirmwareUpdate",
      "light",
      "power",
      "zwave",
      "zwaveAlarm",
    "properties": {
      "zwaveVersion": "3.2",
      "alarmLevel": "0",
      "alarmType": "0",
      "categories": "[\"lights\"]",
      "color": "",
      "configured": true,
      "dead": "false",
      "deadReason": "",
      "deviceControlType": "2",
      "deviceGroup": "[]",
      "deviceGroupMaster": "0",
      "deviceIcon": "125",
      "endPointId": "0",
      "energy": "0.00",
      "firmwareUpdate": "{\"status\":\"UpToDate\",\"updateVersion\":\"\"}",
      "icon": "{\"path\":\"fibaro/icons/com.fibaro.FGWP_EU/plug0.png\",\"source\":\"HC\"}",
      "isLight": "true",
      "log": "",
      "logTemp": "",
      "manufacturer": "",
      "model": "",
      "nodeId": "2",
      "power": "0.00",
      "saveLogs": "true",
      "showEnergy": "true",
      "updateVersion": "",
      "value": "false"
    "actions": {
      "abortUpdate": 1,
      "reconfigure": 0,
      "reset": 0,
      "retryUpdate": 1,
      "startUpdate": 1,
      "turnOff": 0,
      "turnOn": 0,
      "updateFirmware": 1
    "created": 1556381229,
    "modified": 1556381229,
    "sortOrder": 5
