Zigate and aqara in wall switch
gerbenvanasselt
Domoticz version: Beta 4.1
Post by gerbenvanasselt »
Today I installed my aqara double button in wall switch. It was recognized by the Zigate as two separate on/off switches.
I also have a single switch aqara non in wall switch. That one is recognized by Zigate as a selector switch with one click, double - and long click.
I was expecting that the in wall switch also would behave as a selector switch.
What are you're experiences with the aqara in wall switch and Zigate?
Like to hear from you!
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
pipiche
Re: Zigate and aqara in wall switch
Post by pipiche »
Could you provide me the DeviceList-xx.txt file ?
In case you have the pairing log this would be usefull as well
ronaldbro
Post by ronaldbro »
I have the same one, but I think it’s normal. In mi home it’s also just an on/off switch. It also operates a relay and double click doesn’t do anything.
In mi home you can configure each side of the switch as a remote switch and then the relay isn’t connected to the switch anymore and then you can single click/double click/long press. But in zigate you can’t configure that mode. Would be a nice feature for the future...
When you configure this in mi home and you unbind then the setting is gone and it operates normally.
pipiche
Post by pipiche »
If you switch to beta branch and redo the pairing. You will get indeed 2 independent switches and 1 power and 1 meter widget in utility as the switch report watts
tjabas
Post by tjabas »
I also have a double aqara switch, i have paired it with zigate, but it only shows as one selector switch in domoticz, is it possible to pair it do i get 2 independent switches instead, i want to pair the right ens left Button to two different Light bulbs, but with only one selector switch i cant se how i should do that.
tjabas
Post by tjabas »
tjabas wrote: Thursday 29 August 2019 15:38 I also have a double aqara switch, i have paired it with zigate, but it only shows as one selector switch in domoticz, is it possible to pair it do i get 2 independent switches instead, i want to pair the right ens left Button to two different Light bulbs, but with only one selector switch i cant se how i should do that.
pipiche
Post by pipiche »
I beleive you @tjabas you have a wireless double aqara switch, while the post was about a double wired switch which is delivering Power consumption.
tjabas
Post by tjabas »
Aha, thats right, sorry didnt see that.
gerbenvanasselt
@pipiche what ronaldbro is suggesting would be very nice for the in wall switch. That way you can use the inwall switch as a selector switch in Domo.
pipiche
Post by pipiche »
could you summarize it with a concrete example. I'm not sure I completely understood.
I suggest to manage through github this request, so feel free to create an issue on GitHub
https://github.com/pipiche38/Domoticz-Zigate/issues
Please put in perspective today's behaviour and what you would expect.
Then we will have also to see the backward compatibility, but we might work with a flag enabling a particular behaviour or an other.
