Can't add EnOcean sensor device
Posted: Thursday 11 April 2019 13:01
by umpie
How do I add EnOcean Temperature sensors?
I want to connected an Omnio Sensor (which got a STM300-B Module inside)
I connected a AWAG APG03B RS485 gateway interface to my comport (which got a TCM320 module inside)
I paired some sensor with my gateway, and I can nicely see that I get temperature updates and Teach-in messages on my comport.
Now I have added the "Hardware" EnOcean ESP2 to the comport .
And in the log I can see that the "Hardware" EnOcean is receiving the "teach-in" messages, but there is no device added.
There is not themperature sensor added anywhere.
How do I actually add these sensors?
=== LOG ======================================================
2019-04-11 12:39:42.169 Active notification Subsystems: gcm, http (2/13)
2019-04-11 12:39:42.301 Starting shared server on: :::6144
2019-04-11 12:39:42.111 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2019-04-11 12:39:42.112 Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
2019-04-11 12:39:42.112 Status: Startup Path: C:\Program Files\Domoticz\
2019-04-11 12:39:42.162 Status: PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
2019-04-11 12:39:42.174 Status: WebServer(HTTP) started on address: :: with port 8080
2019-04-11 12:39:42.297 Status: WebServer(SSL) started on address: :: with port 443
2019-04-11 12:39:42.298 Status: Proxymanager started.
2019-04-11 12:39:42.301 Status: TCPServer: shared server started...
2019-04-11 12:39:42.302 Status: RxQueue: queue worker started...
2019-04-11 12:39:44.304 Status: EventSystem: reset all events...
2019-04-11 12:39:44.305 Status: EventSystem: reset all device statuses...
2019-04-11 12:39:44.305 Status: EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
2019-04-11 12:39:44.306 Status: EventSystem: Started
2019-04-11 12:39:44.306 Status: EventSystem: Queue thread started...
2019-04-11 12:39:44.518 Status: EnOcean: Using serial port: COM4
2019-04-11 12:39:44.518 Status: EnOcean Send: 55 00 01 00 05 70 08 38
2019-04-11 12:39:44.518 Status: EnOcean Send: 55 00 01 00 05 70 03 09
2019-04-11 12:39:57.173 Status: Incoming connection from: 127.0.0.1
2019-04-11 12:40:25.114 Status: EnOcean: Serial Worker stopped...
2019-04-11 12:40:25.343 Status: EnOcean: Using serial port: COM4
2019-04-11 12:40:38.822 EnOcean: Need Teach-In for Type: 4BS Sender: 018bee12 Data: 9c4da809 Status: 00
2019-04-11 12:40:39.666 EnOcean: Need Teach-In for Type: 4BS Sender: 018bee12 Data: 9c4da809 Status: 00
2019-04-11 12:40:40.690 EnOcean: Need Teach-In for Type: 4BS Sender: 018bee12 Data: 9c4da809 Status: 00
2019-04-11 12:40:51.131 Status: New sensors allowed for 5 minutes...
2019-04-11 12:41:16.720 EnOcean: Need Teach-In for Type: 4BS Sender: 018bee12 Data: 714ca809 Status: 00
2019-04-11 12:41:17.408 EnOcean: Need Teach-In for Type: 4BS Sender: 018bee12 Data: 714ca809 Status: 00
2019-04-11 12:41:17.952 EnOcean: Need Teach-In for Type: 4BS Sender: 018bee12 Data: 714ca809 Status: 00
2019-04-11 12:42:14.872 EnOcean: Need Teach-In for Type: 4BS Sender: 018bee12 Data: 8a51a809 Status: 00
2019-04-11 12:42:15.845 EnOcean: Need Teach-In for Type: 4BS Sender: 018bee12 Data: 8a51a809 Status: 00
2019-04-11 12:42:16.774 EnOcean: Need Teach-In for Type: 4BS Sender: 018bee12 Data: 8a51a809 Status: 00
