multiple textlines in textdevice
Posted: Thursday 11 April 2019 8:40
by Gravityz
i have a textdevice which i use to display the last status.
is there a way to display multiple lines so i can use it as a log.
e.g. i use this comand at the moment
domoticz.devices('Status').updateText('Woonkamer lampen ingeschakeld')
which displays Woonkamer lampen ingeschakeld
now when i issue a second command like
domoticz.devices('Status').updateText('Alarm ingeschakeld')
i want to see the most actual one on top and the other one below
Alarm ingeschakeld
i know this can be done in lua(but i do not know how) butdoes this work in dzvents
Re: multiple textlines in textdevice
Posted: Thursday 11 April 2019 8:50
by zygios
I'm using this:
 departimestext = departimestext .. ' '..departime ..';\r\n'
and result for text device is next:
Status: 08:21:24
08:23:30
08:29:00
You get check in my GIT:
https://github.com/zygios/Domoticz_scri ... nsport.lua
Posted: Thursday 11 April 2019 10:46
by Gravityz
Thanks,
got is working(sort of)
the problem i have now i need to limit the amount of lines to max 5 i think
is there an easy way to do this
this is my code
currentstatus = domoticz.devices('Status').state ..'\r\n'
newstatus = 'Woonkamer lampen sfeervol ingeschakeld'
currentstatus = newstatus .. ';\r\n'..currentstatus ..'\r\n'
domoticz.devices('Status').updateText(currentstatus)
Posted: Thursday 11 April 2019 11:41
by zygios
try this code:
limit_max = 5
for m = 1, limit_max do
	m = m + 1
Posted: Thursday 11 April 2019 11:52
by Gravityz
hm. wonder if this works
this script is called everytime somebody comes/leaves or when a schedule kicks in.
m is not a global variable so i think every time the script is called m=1
in case it does remember after 5 times it will not refresh anymore
Posted: Thursday 11 April 2019 12:01
by zygios
Try this:
limit_max = 4
temp_stastus = ''
m = 1
--removing 5-th status
for i in string.gmatch(currentstatus,  "[^\r\n]+") do
    print(i)
	if m <=4 then
		temp_stastus = temp_stastus .. i.. "\r\n";
		m = m + 1
currentstatus = newstatus .. ';\r\n'..temp_stastus
Posted: Thursday 11 April 2019 13:41
by Gravityz
this indeed works with limiting the messages
however as far as i can see the top line is changing but the others are not.
the idea is that when things change the old messages shift down.
eg
a
b
c
d
e
new message f
f
a
b
c
d
new message h
h
f
a
b
c
i think i need to combine things from the old code and your new code but this is looking promising
Posted: Friday 12 April 2019 8:52
by waaren
Gravityz wrote: Thursday 11 April 2019 13:41 this indeed works with limiting the messages
If I understand your requirement correct, the function addRollingTextLine in below script should do it.
			on =    {
						timer = { 'every minute' },
    logging =   { level   = domoticz.LOG_DEBUG ,
                  marker  = "multiLine text function"},
    execute = function(dz, item)
        local function addRollingTextLine(textDevice, line, maxLines)
            local function stringSplit(str)
                local lines = {}
                for s in str:gmatch("[^\r\n]+") do
                    table.insert(lines, s)
                return lines
            local function checkParms()
                if not textDevice or ( type(textDevice) ~= "string" and type(textDevice) ~= "table" ) then
                    dz.log("textDevice should be of type table or string; now: " .. (tostring(textDevice) or type(textDevice)),dz.LOG_ERROR)
                    return false
                elseif type(textDevice) == "string" then
                    textDevice = dz.devices(textDevice)
                if not line then
                    dz.log("No text supplied",dz.LOG_ERROR)
                    return false
                if not maxLines then maxLines = 5 end          -- default
                return true
            if checkParms() then
                local lines = textDevice.text or ""
                lines = stringSplit(lines)
                lines[0] = line
                local newText = ""
                for i = 0, ( maxLines - 1) do
                    newText = newText ..  ( lines[i] or "" ) .. "\r\n"
                textDevice.updateText(newText)
                return false
        -- Test call
        addRollingTextLine("multiLine", dz.time.raw, 3)
Posted: Saturday 13 April 2019 17:04
by Gravityz
Hi waaren.
that code works very nice
the only downfall is that i need to add it to every script that is updating the status device.
is it possible to put this into some kind of module or helper function.
eg declare it once and then call it from every script you like
Posted: Saturday 13 April 2019 18:54
by waaren
Gravityz wrote: Saturday 13 April 2019 17:04 the only downfall is that i need to add it to every script that is updating the status device.
Have a look here where exactly that is described in detail
Posted: Saturday 13 April 2019 19:45
by Gravityz
Thanks waaren, you made my day.
i have read that myhelper part multiple times over and over again and could not figur out how it was working, until now.
after reading MORE CAREFULLY i noticed what i was doing wrong
working perfectly now
i now can use the Status textdevice as a logging device lights on/of alarm on/off sunscreen in/out. al the things i normally wrote to the log are now visible
