Qubino Zwave node disapeared?!
kimhav
Domoticz version: 2023.2
Post by kimhav »
This morning I noticed that one of indoor lights was still on and it usually it should have been turned off by Domoticz during late evening. So checked the Domoticz switches and noticed that it was marked red by Domoticz which was a bit worrying. So next I checked the OZW active nodes as I kind of expected it to time out but to my surprise it's not even in the list of active or even marked as dead, it's not there anymore?! Wtf, Odd!
Clearly I noticed once I ramp up the number of zwave devices from >10 it seems to generate more errors and I've had until now 2 dead nodes which I performed factory reset on and included again without problem and currently have one node which turns on unscheduled twice per day... But, now having a node just disappearing is a bit alarming. I guess that it's just a matter of factory reset the device and re-adding it again to the network, but having to handle a couple of nodes frequently isn't really what I call a stable system. So clearly there must be something wrong in OZW. And the OZW community isn't really of much help when trying to reach out.
Open for advice and suggestions.
stuiow
Domoticz version: 3.6857
Re: Qubino Zwave node disapeared?!
Post by stuiow »
I get this issue fairly often too, sorry I can't add any help to your issue, but your not alone.
Sent from my SM-G955F using Tapatalk
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
kimhav
Post by kimhav »
Guess that it's an underlying issue with OpenZwave and not Domotivcz which is part of this problem and I've tried to report this to the OpenZwave community and so far no reaction. So does anyone in the this community have direct contact with any of the devs in OpenZwave community or even part of the dev team? Would be nice to get this fixed or perform more steady. And of course it could also be a flaw with the Qubinos.
Kravaldo
Post by Kravaldo »
I'm not able to solve your problem but I have some experience dealing with Qubino support team. They are very fast and reactive so my suggestion is to contact directly the Qubino support team. They should be able to help you.
