Wiegand 26 RFID Reader for Orange/Raspberry Pi
Posted: Wednesday 10 April 2019 8:32
Wiegand 26 RFID Reader for Orange/Raspberry Pi, get the RFID readings key code, into a Domoticz variable (string)
Filename : wiegand.c
* wiegand.c
* Wiegand 26 RFID Reader for Orange/Raspberry Pi, get the RFID readings key code, into a Domoticz variable (string)
* Updated by ILoveIOT 03-04-2019
* By Kyle Mallory All rights reserved.
* 12/01/2013
* Based on previous code by Daniel Smith (www.pagemac.com) and Ben Kent (www.pidoorman.com)
* Depends on the wiringPi library by Gordon Henterson: https://projects.drogon.net/raspberry-pi/wiringpi/
* The Wiegand interface has two data lines, DATA0 and DATA1. These lines are normall held
* high at 5V. When a 0 is sent, DATA0 drops to 0V for a few µs. When a 1 is sent, DATA1 drops
* to 0V for a few µs. There are a few ms between the pulses.
* * IMPORTANT *
* The Raspberry Pi GPIO pins are 3.3V, NOT 5V. Please take appropriate precautions to bring the
* 5V Data 0 and Data 1 voltages down. I used a 330 ohm resistor and 3V3 Zenner diode for each
* connection, or use level shifters like me. FAILURE TO DO THIS WILL PROBABLY BLOW UP THE RASPBERRY PI!
* For compiling use : cd /root/scripts/gpio/ ; gcc -o wiegand -lpthread -lwiringPi -lrt wiegand.c
* For console use : /root/scripts/gpio/wiegand
* For background use : /root/scripts/gpio/wiegand &
* 1. Create a variable in Domoticz to store the value, type variable is a string, mine looks like "KE934802"
* 2. Change the IP address (192.168.8.189) + the name of the variable (RFIDDeur)
* 3. Change the used PINS, I use GPIO 11 and GPIO 21 (#define D0_PIN 11 and #define D1_PIN 21)
* 4. Optional : change the console outputs below
* 5. Optional : You can use Domoticz blocky to trigger a event with the key code
#include <stdio.h>
#include <stdlib.h>
#include <wiringPi.h>
#include <time.h>
#include <unistd.h>
#include <memory.h>
#include <string.h>
#include <assert.h>
// gpio readall | 26 | 1 | ALT2 | GPIO.11 | 11 | 21 |
// | Physical | V | Mode | Name | wPi | BCM |
#define D0_PIN 11
// gpio readall | 7 | 21 | GPIO.21 | ALT2 | 1 | 29 |
// | BCM | wPi | Name | Mode | V | Physical |
#define D1_PIN 21
#define WIEGANDMAXDATA 32
#define WIEGANDTIMEOUT 3000000
static unsigned char __wiegandData[WIEGANDMAXDATA]; // can capture upto 32 bytes of data -- FIXME: Make this dynamically allocated in init?
static unsigned long __wiegandBitCount; // number of bits currently captured
static struct timespec __wiegandBitTime; // timestamp of the last bit received (used for timeouts)
void data0Pulse(void) {
if (__wiegandBitCount / 8 < WIEGANDMAXDATA) {
__wiegandData[__wiegandBitCount / 8] <<= 1;
__wiegandBitCount++;
clock_gettime(CLOCK_MONOTONIC, &__wiegandBitTime);
void data1Pulse(void) {
__wiegandData[__wiegandBitCount / 8] |= 1;
int wiegandInit(int d0pin, int d1pin) {
// Setup wiringPi
wiringPiSetup() ;
pinMode(d0pin, INPUT);
pinMode(d1pin, INPUT);
wiringPiISR(d0pin, INT_EDGE_FALLING, data0Pulse);
wiringPiISR(d1pin, INT_EDGE_FALLING, data1Pulse);
void wiegandReset() {
memset((void *)__wiegandData, 0, WIEGANDMAXDATA);
__wiegandBitCount = 0;
int wiegandGetPendingBitCount() {
struct timespec now, delta;
clock_gettime(CLOCK_MONOTONIC, &now);
delta.tv_sec = now.tv_sec - __wiegandBitTime.tv_sec;
delta.tv_nsec = now.tv_nsec - __wiegandBitTime.tv_nsec;
if ((delta.tv_sec > 1) || (delta.tv_nsec > WIEGANDTIMEOUT))
return __wiegandBitCount;
return 0;
* wiegandReadData is a simple, non-blocking method to retrieve the last code
* processed by the API.
* data : is a pointer to a block of memory where the decoded data will be stored.
* dataMaxLen : is the maximum number of -bytes- that can be read and stored in data.
* Result : returns the number of -bits- in the current message, 0 if there is no
* data available to be read, or -1 if there was an error.
* Notes : this function clears the read data when called. On subsequent calls,
* without subsequent data, this will return 0.
int wiegandReadData(void* data, int dataMaxLen) {
if (wiegandGetPendingBitCount() > 0) {
int bitCount = __wiegandBitCount;
int byteCount = (__wiegandBitCount / 8) + 1;
memcpy(data, (void *)__wiegandData, ((byteCount > dataMaxLen) ? dataMaxLen : byteCount));
wiegandReset();
return bitCount;
return 0;
void main(void) {
int i;
wiegandInit(D0_PIN, D1_PIN);
while(1) {
int bitLen = wiegandGetPendingBitCount();
if (bitLen == 0) {
usleep(5000);
} else {
char data[100];
bitLen = wiegandReadData((void *)data, 100);
int bytes = bitLen / 8 + 1;
// because we get the data from a loop I had to make a virtual file and store the value's from the loop into file and into char "buf"
char *buf;
size_t size;
FILE *fp = open_memstream(&buf, &size);
assert(fp);
// Doing the loop, we get 2 value's at the same time, 4 times, print them in a file, in 1 code.
for (i = 0; i < bytes; i++) {
fprintf(fp, "%02X", (int)data[i]);
// Close the virtual file
fclose(fp);
// Making the string with the RFID data for Domoticz
char str1[] = "/bin/bash -c 'curl -i -s \"http://192.168.8.189:8080/json.htm?type=command¶m=updateuservariable&vname=RFIDDeur&vtype=2&vvalue=";
// Get the value from "buf" the keycard code, and put it in a string
char str2[25]; //size of the number
sprintf(str2, "%s", buf);
// Uncomment one off the lines if you wanna see output or not from domoticz
char str3[] = "\"' > /dev/null 2>&1";
//char str3[] = "\"'";
// Put the strings together
strcat(str2,str3);
strcat(str1,str2);
// Sending data to Domoticz, in the already prepared string
system(str1);
// Uncomment if you wanna see the line sending to Domoticz
//puts(str1);
// Uncomment if you wanna see the output of "buf" on the console
//puts(buf);
free(buf);
