Philips Hue Lightstrip/bulbs can be pairing with ZIGATE?
pfloryann
Domoticz version: 2025.2
Post by pfloryann »
I want to buy Philips Hue Lightstrip Plus and i want to control it with Zigate, i haven't philips bridge. Is possible or not?
Thx
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5
pipiche
Re: Philips Hue Lightstrip/bulbs can be pairing with ZIGATE?
Post by pipiche »
Did you check : https://github.com/pipiche38/Domoticz-Z ... Devices.md
I would say that it should work, as all Hue devices are working with Zigate. Plugin adaptation might have to be done. Depends.
The only issue is make sure to have a Hue Remote in order to be able to reset it
pfloryann
Post by pfloryann »
Hi I Bought Philips Hue Strip Plus and Philips Hue Remote. I paired light strip with zigate and she working fine. Then i paired light strip with remote and from that moment light strip not working with zigate!!! On zigate website say that remote hue is compatible with zigate, but how?
pipiche
Post by pipiche »
Did you try to pair the Remote Hue with Zigate before ?
I would suggest to do the following:
1- Reset the Hue strip and pair it with the Zigate
2- Reset the Hue remote and pair it with the Zigate ( you have a setup hole on the back of the remote hue. You need to press about 10s until the led flash on the Remote front side). This will create a Widget on Domoticz
3- Pair the Hue remote with the Strip
pfloryann
Post by pfloryann »
Super...i followed your instructions and is working now. Thank you !
I noticed that light strip status is not changing if i swiched on/off from remote, only the remote status is working. I waited 1h for light strip status and nothing. Can you check?
pipiche
Post by pipiche »
pfloryann wrote: Friday 23 August 2019 0:02 Super...i followed your instructions and is working now. Thank you !
Could you please attach the log file from the time you did the pairing ?
and please do attach the file Data/DeviceList-xx.txt
pfloryann
Post by pfloryann »
Banda Phlips Hue - is name of light strip
Intrerupator Philips - is name of Remote
2019-08-23 21:09:29.812 (Zigate) UpdateDevice - (Banda Philips Hue) 1:On - sent from domoticz
2019-08-23 21:09:29.797 Status: User: florian initiated a switch command (152/Banda Philips Hue/On) - sent from domoticz
2019-08-23 21:14:08.645 (Zigate) UpdateDevice - (intrerupator Philips) 1:On - sent from remote
2019-08-23 21:14:18.462 (Zigate) UpdateDevice - (intrerupator Philips) 0:Off - sent from remote
... nothing else in log file about light strip.
Remote status is changed but not for light strip. The light strip status is changing only when sent command from domoticz.
DeviceList-5.txt
(39.47 KiB) Downloaded 41 times
pipiche
Post by pipiche »
without the logs during pairing I cannot do anything.
pfloryann
Post by pfloryann »
I deleted from domoticz devices list Light strip and Remote....i tried to pairing again with zigate, light strip was done..but Remote do not create widget and is not in domoticz devices list ..........
2019-08-24 14:30:29.245 (Zigate) Decode8701 - Route discovery has been performed, status: 00 Nwk Status: d0
2019-08-24 14:30:30.248 (Zigate) Decode8701 - Route discovery has been performed, status: 00 Nwk Status: 00
2019-08-24 14:30:33.286 Status: (Zigate) [0] NEW OBJECT: 22c8 Request Model Name
2019-08-24 14:30:33.289 Status: (Zigate) [0] NEW OBJECT: 22c8 Request Attribute for Cluster 0x0300 to get ColorMode
2019-08-24 14:30:35.979 (Zigate) UpdateDevice - ( Usa intrare) 0:Closed
2019-08-24 14:30:38.295 (Zigate) Too early, let's try to get the Model
2019-08-24 14:30:38.294 Status: (Zigate) [1] NEW OBJECT: 22c8 Model Name: LST002
2019-08-24 14:30:43.320 (Zigate) GetType - Model LST002 Profile ID : a1e0 ZDeviceID : 0061
2019-08-24 14:30:43.320 (Zigate) GetType - Model LST002 not found with Ep: 0b in DeviceConf. Continue with ClusterSearch
2019-08-24 14:30:43.320 (Zigate) GetType - ClusterSearch return : Switch/LvlControl/ColorControl
2019-08-24 14:30:43.321 (Zigate) subtypeRGB_FromProfile_Device_IDs - Model: LST002, ProfileID: a1e0, ZDeviceID: 0061 ColorInfos: {'X': '29972', 'Saturation': 140, 'Y': '26871', 'Hue': 32, 'ColorTemperatureMireds': '366', 'ColorMode': 2}
2019-08-24 14:30:43.321 (Zigate) subtypeRGB_FromProfile_Device_IDs - ProfileID: a1e0 ZDeviceID: 0061 Subtype: 4
2019-08-24 14:30:43.324 (Zigate) GetType - Model LST002 Profile ID : a1e0 ZDeviceID : 0061
2019-08-24 14:30:43.324 (Zigate) GetType - Model LST002 not found with Ep: f2 in DeviceConf. Continue with ClusterSearch
2019-08-24 14:30:43.324 (Zigate) GetType - ClusterSearch return :
2019-08-24 14:30:43.325 (Zigate) Request a Bind for 22c8/0b on Cluster 0006
2019-08-24 14:30:43.326 (Zigate) Request a Bind for 22c8/0b on Cluster 0008
2019-08-24 14:30:43.327 (Zigate) Request a Bind for 22c8/0b on Cluster 0300
2019-08-24 14:30:43.327 (Zigate) Request a Bind for 22c8/0b on Cluster 0000
2019-08-24 14:30:43.602 (Zigate) Decode8030 - Bind response SQN: bf status [8c] - The device does not have table space to support the operation.
2019-08-24 14:30:43.704 (Zigate) Decode8030 - Bind response SQN: c0 status [8c] - The device does not have table space to support the operation.
2019-08-24 14:30:43.805 (Zigate) Decode8030 - Bind response SQN: c1 status [8c] - The device does not have table space to support the operation.
2019-08-24 14:30:43.318 Status: (Zigate) [2] NEW OBJECT: 22c8 Model Name: LST002
2019-08-24 14:30:44.111 (Zigate) Decode8030 - Bind response SQN: c3 status [8c] - The device does not have table space to support the operation.
2019-08-24 14:30:44.318 (Zigate) Decode8030 - Bind response SQN: c4 status [8c] - The device does not have table space to support the operation.
2019-08-24 14:30:44.524 (Zigate) Decode8030 - Bind response SQN: c5 status [8c] - The device does not have table space to support the operation.
2019-08-24 14:30:44.841 (Zigate) UpdateDevice - (Zigate - LST002_ColorControlRGBWW-00178801044ae54a-0b) 1:100
2019-08-24 14:30:45.400 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0006 - Attribute: 0000 - Attribute Type: 10
2019-08-24 14:30:45.400 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0006 - Attribute: 4000 - Attribute Type: 10
2019-08-24 14:30:45.402 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0006 - Attribute: 4001 - Attribute Type: 21
2019-08-24 14:30:45.404 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0006 - Attribute: 4002 - Attribute Type: 21
2019-08-24 14:30:45.507 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0005 - Attribute: 0000 - Attribute Type: 20
2019-08-24 14:30:45.508 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0005 - Attribute: 0001 - Attribute Type: 20
2019-08-24 14:30:45.508 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0005 - Attribute: 0002 - Attribute Type: 21
2019-08-24 14:30:45.509 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0005 - Attribute: 0003 - Attribute Type: 10
2019-08-24 14:30:45.510 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0005 - Attribute: 0004 - Attribute Type: 18
2019-08-24 14:30:45.715 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0008 - Attribute: 0000 - Attribute Type: 20
2019-08-24 14:30:45.718 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0008 - Attribute: 0001 - Attribute Type: 21
2019-08-24 14:30:45.820 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0000 - Attribute: 0000 - Attribute Type: 20
2019-08-24 14:30:45.821 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0000 - Attribute: 0001 - Attribute Type: 20
2019-08-24 14:30:45.822 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0000 - Attribute: 0002 - Attribute Type: 20
2019-08-24 14:30:45.822 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0000 - Attribute: 0003 - Attribute Type: 20
2019-08-24 14:30:45.823 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0000 - Attribute: 0004 - Attribute Type: 42
2019-08-24 14:30:45.824 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0000 - Attribute: 0005 - Attribute Type: 42
2019-08-24 14:30:45.824 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0000 - Attribute: 0006 - Attribute Type: 42
2019-08-24 14:30:45.825 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0000 - Attribute: 0007 - Attribute Type: 30
2019-08-24 14:30:45.826 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0000 - Attribute: 4000 - Attribute Type: 42
2019-08-24 14:30:45.928 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0004 - Attribute: 0000 - Attribute Type: 18
2019-08-24 14:30:46.132 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0003 - Attribute: 0000 - Attribute Type: 21
2019-08-24 14:30:46.237 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0000 - Attribute Type: 20
2019-08-24 14:30:46.239 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0001 - Attribute Type: 20
2019-08-24 14:30:46.241 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0002 - Attribute Type: 21
2019-08-24 14:30:46.243 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0003 - Attribute Type: 21
2019-08-24 14:30:46.245 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0004 - Attribute Type: 21
2019-08-24 14:30:46.249 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0007 - Attribute Type: 21
2019-08-24 14:30:46.253 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0008 - Attribute Type: 30
2019-08-24 14:30:46.255 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0010 - Attribute Type: 20
2019-08-24 14:30:46.257 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0011 - Attribute Type: 21
2019-08-24 14:30:46.259 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0012 - Attribute Type: 21
2019-08-24 14:30:46.261 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0013 - Attribute Type: 20
2019-08-24 14:30:46.263 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0015 - Attribute Type: 21
2019-08-24 14:30:46.266 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0016 - Attribute Type: 21
2019-08-24 14:30:46.267 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0017 - Attribute Type: 20
2019-08-24 14:30:46.267 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0019 - Attribute Type: 21
2019-08-24 14:30:46.268 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 001a - Attribute Type: 21
2019-08-24 14:30:46.269 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 001b - Attribute Type: 20
2019-08-24 14:30:46.269 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0030 - Attribute Type: 21
2019-08-24 14:30:46.270 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0031 - Attribute Type: 21
2019-08-24 14:30:46.272 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0032 - Attribute Type: 21
2019-08-24 14:30:46.274 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0033 - Attribute Type: 21
2019-08-24 14:30:46.276 (Zigate) Decode8140 - Attribute Discovery Response - 22c8/0b - Cluster: 0300 - Attribute: 0034 - Attribute Type: 20
2019-08-24 14:40:11.605 (Zigate) Decode8701 - Route discovery has been performed, status: 00 Nwk Status: 00
2019-08-24 14:40:11.707 (Zigate) Decode8701 - Route discovery has been performed, status: 00 Nwk Status: 00
2019-08-24 14:40:11.591 Status: (Zigate) Device Annoucement ShortAddr: 3628, IEEE: 0017880106ea0be5
2019-08-24 14:40:11.591 Status: (Zigate) NetworkID : 3628 is replacing 1dd8 and is attached to IEEE : 0017880106ea0be5
2019-08-24 14:40:28.929 (Zigate) Permit Join status: 00
2019-08-24 14:40:28.929 (Zigate) ---> self.permitTojoin['Starttime']: 1566646573
2019-08-24 14:40:28.929 (Zigate) ---> Current time : 1566646828
2019-08-24 14:40:28.929 (Zigate) ---> self.Ping['Permit'] (prev) : On
2019-08-24 14:40:28.929 (Zigate) ---> self.Ping['Permit'] (new ) : Off
2019-08-24 14:40:36.179 (Zigate) Decode004d - rebind clusters for 22c8
2019-08-24 14:40:36.184 (Zigate) Decode8701 - Route discovery has been performed, status: 00 Nwk Status: 00
2019-08-24 14:40:36.179 Status: (Zigate) Device Annoucement ShortAddr: 22c8, IEEE: 00178801044ae54a
When i trying to pair again Remote with zigate and is not working:
2019-08-24 15:03:46.088 Status: (Zigate) Device Annoucement ShortAddr: dd9a, IEEE: 0017880106ea0be5
2019-08-24 15:03:46.088 Status: (Zigate) NetworkID : dd9a is replacing a832 and is attached to IEEE : 0017880106ea0be5
pipiche
Post by pipiche »
For the remote, may be you didn't remove it completely from Domoticz. Did you search in the Device list for : 0017880106ea0be5
If there is no reference in Domoticz to that, please do the following
(1) stop the plugin (or domoticz)
(2) edit the file Data/DeviceList-xx.txt
(3) search for 0017880106ea0be5 and remove that line
Then you can restart the plugin and pair the Hue remote
For the state, you might enable the polling.
(1) go to the Plugin Web Admin (on port 9440 )
(2) Settings
(3) Enable polling
Eventually you can adjust the polling frequency by using Advanced Setting and go to the Polling section
pollingONOFF is the frequency to query On/Off state
pollingLvlControl is the frequency to query Level
By default it is set to 900 seconds ( 15 minutes) . You can reduce the elapse time between 2 polling, but please do consider that the polling will be done with every single device having a On/Off and/or LvlControl capabilities. So on a large network it could be quiet heavy in terms of traffic generated.
pfloryann
Post by pfloryann »
Yes, all is fine now. I deleted 2 rows 1 for remote control and 1 row for notification from devicelist. Thank you again!
pipiche
[SOLVED] Philips Hue Lightstrip/bulbs can be pairing with ZIGATE?
Post by pipiche »
