Help needed blocklyscript doorsensor toilet
Posted: Thursday 04 April 2019 9:12
by yazoo
i have a door sensor
what i want is is the door is open light goos on. but then when the door is kloos and goos open witin 7 minutes from het first time the door is open it me not sent that the light goos on
what i have now is
if-->sensor1=Alarm
do set-->WC lamp=on
who can help me finist this script if it dont can with blockly then with an another script.
Re: Help needed blocklyscript doorsensor toilet
Posted: Thursday 04 April 2019 11:13
by Gerwin
more info is more than welcome
wich sensor are you using only open state or open and close
picture of your blockly
gerwin
Posted: Thursday 04 April 2019 11:47
by yazoo
Gerwin wrote: Thursday 04 April 2019 11:13 more info is more than welcome
gerwin
this a simpel door magneet kerui state normal/alarm (same as open and close)
the script what if have works only it isnt finnist en that i dont no how to do.
if-->sensor1=Alarm
do set-->WC lamp=on
Posted: Thursday 04 April 2019 12:08
by kuifje
Yazoo,
You have to use a user variable.
When sensor1 is alarm and sensor1 is 0
Set sensor1 to 1
Set wclamp to on
If sensor1 is no alarm and sensor1 is 1
Set wclamp off
Use the if else blockly. The one with the blue shizzle.
Mabey this will get you in the right direction
Kuifje
Posted: Thursday 04 April 2019 12:12
by Gerwin
Make a dummy switch and make them a timer and set the time you want that the light must go out
And use the block and
Like : if sensor 1 =alarm and timer is off
Set timer on
Set wc lamp on
Posted: Friday 05 April 2019 9:07
by yazoo
kuifje wrote: Thursday 04 April 2019 12:08 Yazoo,
Set sensor1 to 1
Set wclamp to on
Set wclamp off
Kuifje
hello kuifje can you please help me i try to make what you are writen ,but i am a biginner i do somting not goed. this is wat i have.
Posted: Friday 05 April 2019 12:48
by kuifje
Yazoo,
you have to use 1 if do blockly en put the else under the if. ( example )
The user variable has to be integer. ( Example )
Kuifje
