Cannod add Xiaomi Gateway
Posted: Sunday 31 March 2019 22:53
Hello to this wonderful community.
I am using Domoticz + 2 Xiaomi Gateway v2 (x2) for many months now and I am very satisfied.
Currently I am in a need to add 3rd gateway, but completly no luck with with getting it into Domoticz->Setup->Devices->Not used
You know, there should be "Alarm Clock", "Dorbell", "MP3" devices there after adding Gateway into "Domoticz->Setup->Hardware"
I am loosing my mind and almost giving up. Unable to continue by myself. Please lovely community, help me get this through.
Facts, maybe not all related but all I know
* have tried with clean instance of Domoricz, with no configs, no prev Xiaomi gateways, only new one. Pure clean instalation @ V4.10602
* was using tutorial from https://www.domoticz.com/wiki/Xiaomi_Ga ... e_gateways
* my router is connected to 16p switch (not managed) and NAS (where Domoticz lives) is connected to switch with 2 LANs (link aggregation) and my WiFi comes from AccessPoint "Unifi AC Lite" also connected to Switch (1 cable with POE). This means all devices are in same network class.
* Using router: EdgeRouter X , firmware v1.10.9 (newest).
** There is no "IGMP Proxy" config on a router because Domoticz(Synology) is connected to switch over LAN, and Xiaomi Gateways via AccessPoints (Wifi 2,4GHz) on same network. So UDP Broadcasting should work correctly.
** there is Link Aggregation on NAS, but Synology solves this right by giving me one LAN interface on Synology~Docker machine (where Domoticz works):
** (in past, this enabled me to add 1st and 2nd gateway, no problem)
** Domoticz is on Synology NAS: a Docker container/Linux that is using "Host Network", meaning, Domoticz-machine is visible in same main network and Gateways, or router/switch
* I'm really bad with networks (probably)
Please come with any suggestions. Maybe this setup is uncommon, but at the end of a day, its just LAN, domoticz and Xiaomi gateway.
Help me ObiOneCommunity, You're my only Hope.
* Using Domoticz V4.10602. Compiled it myself from develop branch today, because this one had "multiple gateways" support.```
ovs_bond0 Link encap:Ethernet HWaddr 00:11:32:8E:2B:6D
inet addr:192.168.1.146 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: (..navermind..) Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:105258250 errors:0 dropped:0 overruns:0 frame:0
TX packets:49223200 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1
RX bytes:463710874212 (431.8 GiB) TX bytes:229642597134 (213.8 GiB)
