Influxdb and updateCustomSensor
Posted: Sunday 31 March 2019 17:14
All,
I have started using the option to push data to Influxdb but if a dummy sensor is updated by the function "updateCustomSensor", the data is not send to influxdb. I have read the wiki and this seems to be by design. Now I am using the json call to domoticz to update the dummy sensor using the following helper function in the "global_data.lua" and this works fine, Influxdb is updated perfectly.
It would be nice however if the "updateCustomSensor" has the same effect on the pushdata function, is this possible to realize in one of the next dzvents version?
regards
pushInfluxdb = function (domoticz, device, Arg1, Arg2, Arg3, Arg4, Arg5, Arg6)
local tempUrl = "http://xxx.xxx.xxx.xxx:8080/json.htm?type=command¶m=udevice&idx=" .. device .. "&nvalue=0&svalue=" .. Arg1..";" ..Arg2..";" ..Arg3..";" ..Arg4..";" ..Arg5..";" ..Arg6
domoticz.openURL({
url = tempUrl,
method = 'GET',
endIt would be nice however if the "updateCustomSensor" has the same effect on the pushdata function, is this possible to realize in one of the next dzvents version?
regards
