One hardware device -> 2 node in zwave config
Posted: Friday 29 March 2019 22:05
by multinet
Hello
Using UZB1 on last stable version of domoticz (raspi)
After multiple actions on my zwave device I've now a trouble :
In my zwave device liste i've 2 device for 1 hardware
Capture d’écran 2019-03-29 à 21.58.46.jpg (322.4 KiB) Viewed 5889 times
Devices : 012 = 048 / 022=044 / 029=043 / 032 = 045 / 033=046 / 034= 047
All are FIBARO Smoke sensor FGSD002
I tried multiple things :
- remove from zwave node screen : they reappear
- stop domoticz / edit zwave cfg file (remove all OLD node)/ restart domoticz : they reappear
- go in panel config zwave -> delete node : it doesn't end successfully : : they reappear
- tried to remove from network node : by selecting the remove option in list, press 3 times on smoke sensor ---> it removeds only the correct node in zawave list, the wrong node still present
As you can see in screen shot manufacturer is empty and ID + type are at 0x0000
Of course in my device liste (the other menu) I've multiple entries for each fantom nodes : smoke, general, heat etc.
Do you have any idea on how I can remove them ?
Thank you
Multinet
