description of each zwave "device"
multinet
Post by multinet »
Hello
I wonder where I can find a description of each "device" that domoticz add for one fibaro module.
I use :
- FGMS001-ZW5 (motion sensor+)
- FGSD002 (smoke sensor+)
- FGRM222 (Roller Shutter controller 2)
- FGS223 (double relay)
- FGRGBWM441 (RGBW Controller)
- FGFS001 (Flood Sensor)
For example I want to know the description for all this device (for FGFS001) :
Capture d’écran 2019-03-29 à 13.02.33.jpg (128.54 KiB) Viewed 532 times
Thank you
Multinet
PI 2 - Domoticz 2021.1
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver (5 DIO 54755 + 2 DIO 54756 + 3 DIO 54798)
Z-Wave.Me ZME_UZB1 USB Stick (6 FGSD002 + 2 FGRM222 + 1 FGS223 + 1 FGMS001-ZW5 + 1 FGRGBWM441 + 1 FGBS001 + 2 FGFS101)
6 sondes DS18B20
pvm
Domoticz version: 4.10538
Re: description of each zwave "device"
Post by pvm »
The text / type and value columns helps in this. There is no other description in Domoticz or Fibaro manuals and it might also be dependent on the Fibaro firmware being used
