MQTT Sync Issue
Posted: Thursday 28 March 2019 12:25
by emme
I use to sync status between KNX and devices from MQTT
I do sometines have issues with some loops due to repeated telegrams between domoticz/in and domoticz/out topics.
If I switch on a device via MQTT and this device is already On, it generates a telegram in the MQTT topic domoticz/out.
Could it be possible to avoid those kind of messages (or configure it for each device) in case of no state change?
thanks
ciao
M
Re: MQTT Sync Issue
Posted: Thursday 28 March 2019 15:55
by FireWizard
How do you connect KNX to Domoticz?
Are you using Mosquitto as MQTT broker?
If so do you use Node-Red to prepare the topics for Domoticz?
In that case you could probably use a node called RBE (Report by Exception).
Re: MQTT Sync Issue
Posted: Thursday 28 March 2019 16:45
by emme
I use KNXJS Node to connect and I already use RBE in the flow to ensure not to send equals payload and send/receive in MQTT to domoticz
I have 2 issues with the flow:
1) same status on the telegrams generate a useless information (blocked by RBE)
2) quick push on the KNX side will generate a loop of 0 / 1 on payload that are not blocked by RBE
this evening I will try insert a delay node of 200ms to see if this could solve the issue
but the problem persists:
Scenario: KNX Off - Domoticz ON
ACTIONS: ON on KNX ==> send ON to domoticz ==> receive ON From Domoticz ==> send ON to KNX ==> Device status does not reply to same status
The receive ON is quite useless
ACTION:
Quick ON/OFF on KNX ==> [KNX] send On to Dz ==> [KNX] send OFF to Dz ==> [DZ] Receive ON ==> [Dz] Receive Off ==> [Dz] Send ON to KNX ==> [KNX] Send ON to Dz==> [Dz] send Off to KNX
Result: LOOP!!!!
this is a big deal to me... but will dig my way out
