WiFi power strips?
Plantje
WiFi power strips?
Post by Plantje »
Currently I have two Greenwave power strips with 6 outlets. It is a pity that they are not sold anymore.
So I started looking for an alternative and found stuff like:
https://nl.aliexpress.com/wholesale?cat ... mart+strip
Will it be possible to add those to Domoticz?
emme
Domoticz version: latest
Re: WiFi power strips?
Post by emme »
I'm using Meross and I'm feeling pretty good with them
I use a python script to send ON/OFF command and Alexa via NodeRed to get them Sync with domoticz
I'm not able to write a plugin for them, but this is somthing I would try in the future
ciao
M
"We always done this way"
Prutsium
Post by Prutsium »
Seems https://nl.aliexpress.com/item/Wifi-Sma ... 86078.html that there is an ESP8285 inside and is possible to get Tasmota on it.
More info on that: https://github.com/arendst/Sonoff-Tasmo ... -USB-ports
Plantje
Post by Plantje »
I'm a little bit confused...
So, it is not possible to buy a WiFi power strip, hit some sort of connect button and add the device to Domoticz in a way that is similar to adding Z-Wave devices or 433Mhz devices?
emme
Post by emme »
nope... it does not works like that...
You buy the power stripe, add a virtual button (one per each outlet on the stripe) and activate a script that will interact with the vendor cloud.
Note that those outlets do NEED internet connection, unless they would not work.
Eravinera
Post by Eravinera »
I am new to this question. Tell me, please, how can I increase the WiFi signal?
Plantje
Post by Plantje »
emme wrote: Friday 22 March 2019 14:25 nope... it does not works like that...
Thank you for that reply. So, this is not at all an alternative to the Greenwave Powernode 6. Too bad :(
Plantje
Post by Plantje »
Eravinera wrote: Tuesday 26 March 2019 17:22 I am new to this question. Tell me, please, how can I increase the WiFi signal?
Please start a separate topic....
