email notification on openwrt os
sash
Post by sash »
Hi there I being trying to get gmail to work with the notification - but I am not certain if I have all the prequisites installed for it as it is an openwrt install.. when I check through your forum threads others get more of an error code in the logs then I am getting
all I get is this as a error log
2019-03-20 21:05:45.835 Notification sent (email) => Failed
2019-03-20 21:05:45.848 Active notification Subsystems: email (1/13)
so I am not sure if the prerequisite are all installed for email on domoticz since openwrt tends to install only the very base requirements.. are there other prequisits that might be required..
sazaki
Re: email notification on openwrt os
Post by sazaki »
I am having the same issue with email notification on openwrt. Have you solved it?
Sazaki
sazaki
Post by sazaki »
Email notification is managed by libcurl package. I have re-compiled this package with SMTP enabled. I have removed domoticz , installed the newly compiled package(libcurl) then reinstalled domoticz. Now email notification works.
