to rookie to get it...
Posted: Monday 18 March 2019 19:34
by bozidar
Hi all
I have in rooms that are mainly controlled by PIR a need for more control.
I am trying to implement that spots dim to 50% light between 20:00 and 2300 and 30% between 23:00 and 5:30 .and 50% between 5:30 and 630
BUT the big issue is light switch need to be able to increase to 100% if pressed and overule dimming.
Light switches are "digital" and ON signal when pressed ,and otherwise off.
Is that even possible
Re: to rookie to get it...
Posted: Monday 18 March 2019 21:42
by waaren
bozidar wrote: Monday 18 March 2019 19:34
BUT the big issue is light switch need to be able to increase to 100% if pressed and overrule dimming.
Could be something like
-- Time & Switch control
dim50Evening = "at 20:00"
dim30Night = "at 23:00"
dim50Morning = "at 5:30"
Off = "at 6:30"
on = { timer = {
dim50Evening,
dim30Night,
dim50Morning,
Off,
devices = {
"your Switch",
logging = { level = domoticz.LOG_DEBUG,
marker = "Time & Switch control" },
data = { dimLevel = { initial = 50 }},
execute = function(dz,item)
local light = dz.devices("your dimmable light")
local function logWrite(str,level)
dz.log(tostring(str),level or dz.LOG_DEBUG)
if item.isTimer then
if dz.time.matchesRule(dim50Evening) or dz.time.matchesRule(dim50Morning) then
dz.data.dimLevel = 50
elseif dz.time.matchesRule(dim30Night) then
dz.data.dimLevel = 30
dz.data.dimLevel = 0
light.dimTo(dz.data.dimLevel)
else -- triggered by Switch
if item.state == "On" then -- Switch is On
dz.data.dimLevel = light.level -- store current Level
light.dimTo(100) -- full Power to the light
light.dimTo(dz.data.dimLevel) -- Restore to old dimLevel
