No dzvents log on the domoticz log page
Posted: Saturday 16 March 2019 19:46
by snellejellep
For some time now, i do not seem to get any dzvents log messages in my log, which i previously did get.
I view my log from settings > log in the web interface.
someone else having this problem?
i have it for a couple of months now and updated to various betas, now running the current latest V4.10547 but it still does not seem to work.
i even changed the loglevel for dzvents in the settings to debug but that does not seem to make any difference.
i hope someone can help me.
Re: No dzvents log on the domoticz log page
Posted: Saturday 16 March 2019 21:41
by waaren
snellejellep wrote: Saturday 16 March 2019 19:46
Can you share your /etc/init.d/domoticz.sh ?
Do you select "All" at the log tab ?
Did you cleared cache and appcache after the last update ?
Posted: Monday 18 March 2019 17:56
by snellejellep
waaren wrote: Saturday 16 March 2019 21:41
i did all of that, this is my domoticz.sh:
https://snellejellep.stackstorage.com/s/yM59Njojl26elie
Posted: Monday 18 March 2019 18:08
by waaren
Can you try to change the current line
DAEMON_ARGS="$DAEMON_ARGS -log /tmp/log/domoticz.log -loglevel normal"
in /etc/init.d/domoticz.sh
and make it
DAEMON_ARGS="$DAEMON_ARGS -log /tmp/log/domoticz.log"
DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error"
after that stop and start domoticz (a restart might not be enough to pick up these changes).
When stopping domoticz you will see a message like
Warning: domoticz.service changed on disk. Run 'systemctl daemon-reload' to reload units.
This is normal behavior. Just do a
to reload them before giving the start command (only needed once).
Re: No dzvents log on the domoticz log page [SOLVED]
Posted: Monday 18 March 2019 19:16
by snellejellep
waaren wrote: Monday 18 March 2019 18:08
and make it
Thank you, this works but am i supposed to get dzvents debug log messages? i do not remember getting those but that may be new.
Posted: Monday 18 March 2019 20:29
by waaren
snellejellep wrote: Monday 18 March 2019 19:16
dzVents Log Level is controlled separately:
using the domoticz web GUI interface: choose [setup] [settings] [other] and at the bottom you will find the dzVents Log Level where you can pick one of the 5 different levels
Posted: Monday 18 March 2019 20:30
by snellejellep
Right, i ineed changed that in trying to fix the issue. Massive thanks!
Verstuurd vanaf mijn SM-G975F met Tapatalk
