Blocky runs in continous loop until no condition exist
Posted: Saturday 16 March 2019 19:13
Hi there your blocky runs in a continuous loop until all condition do not exist which makes it kind of silly for the if/else statements as it makes it kind of useless for alot of things
example: a dimming control
xiaomi cube:
instead of finishing when the first condition is met it will start from the top again and loop trough until all conditions are met and it can not do any more . so it always ending up on the lowest setting . you can see it stepping through if you add a timer condition on the do
Ie:
perhaps this is by design or a bug. if by design can you introduce an extra blocky logic just to introduced an end loop condition.
ie:
xiaomi cube:
if "cube" = "rotate right" and "dimmer" = set level 20%
do "dimmer" = level 1%
else if "cube" = "rotate right" and "dimmer" = set level 40%
do "dimmer" = level 20%
else if "cube" = "rotate right" and "dimmer" = set level 60%
do "dimmer" = level 40%
else if "cube" = "rotate right" and "dimmer" = set level 80%
do "dimmer" = level 60%
else if "cube" = "rotate right" and "dimmer" = set level 100%
do dimmer = level 80%Ie:
do "dimmer" = level 80% after 2 seconds ie:
stop
stop
stop
stop
stop
