Multi-position control for RFXCOM
ccaru
Post by ccaru »
Does anybody know if there exist any RFXCOM supported wall mounted switches which contain multiple positions (i.e. more than an on/off command?)
I am looking to implement the following: I have a motion sensor which i would like to permanently override as always on or always off.
So ideally on the wall I would have a three button switch which I can program to do the following:
Position 1 : Always on
Postiion 2 : Motion Sensor Activated
Position 3 : Always Off
I know I can acheive this with two regular switches but I am trying to find something which can fit in place of a standard light switch!
RFXCom, Somfy RTS, 433Mhz Lighting, Evohome, Smart watering via Netatmo, solenoid valves, soil humidity sensors, Airthings Radon via bluetooth, Marley heat recovery fresh air units, Blue Iris, Alexa via DA Bridge.
