Thank you!
Detailed temperature data for more than 24 hours
Metlik
Is it possible to see the detailed temperature graph for more than last 24 hours? Temperature graph for last month is not so precise...
Thank you!
Thank you!
- waaren
Re: Detailed temperature data for more than 24 hours
Use [setup] [system] [Log History] [Short Log Sensors] to choose 1 - 7 days worth of data in short term log.Metlik wrote: Tuesday 12 March 2019 20:16 Is it possible to see the detailed temperature graph for more than last 24 hours? Temperature graph for last month is not so precise...
Thank you!
kimot
- Domoticz version: v3.8153
You can setup Domoticz to send data to InluxDB.
So you have got all detail data from your history.
Visualisation with Grafana, for example.
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
1 x Shelly 1
1 x RFLink
4x Cam IPC-T240H
Prutsium
Example of Domotixz > Influx > Grafana:
https://snapshot.raintank.io/dashboard/ ... fysUe9jQHX
In this setup various devices put their data directly into Influx and a few devices are pushed by Domoticz into Influx.
At the end visualization is made by Grafana.
