Motion or sound detection on a Foscam IP camera with the API - CGI
Posted: Sunday 10 March 2019 0:17
When sending the following command in a browser to his Foscam camera:
We receive the following answer:
In the response, the lines "<motionDetectAlarm> 1 </ motionDetectAlarm>" and "<soundAlarm> 1 </ soundAlarm>" are interesting because the variable changes from "1" to "2" when motion or sound is detected.
With the command curl in a script in LUA in domoticz:
We can also send the command, but I do not find how to put the 2 lines "<motionDetectAlarm> 1 </ motionDetectAlarm>" and "<soundAlarm> 1 </ soundAlarm>" in a variable to change a virtual inter in domoticz?
Would be really convenient to do some scenario in case of alarm.
If you have any ideas ...
http://192.168.1.xx:xx/cgi-bin/CGIProxy.fcgi?cmd=getDevState&usr=xxxxx&pwd=xxxxxCode: Select all
<CGI_Result>
<result>0</result>
<IOAlarm>0</IOAlarm>
<motionDetectAlarm>1</motionDetectAlarm>
<soundAlarm>1</soundAlarm>
<record>0</record>
<sdState>0</sdState>
<sdFreeSpace>0k</sdFreeSpace>
<sdTotalSpace>0k</sdTotalSpace>
<ntpState>1</ntpState>
<ddnsState>0</ddnsState>
<url>http%3A%2F%2Flg3102.myfoscam.org%3A85</url>
<upnpState>0</upnpState>
<isWifiConnected>0</isWifiConnected>
<wifiConnectedAP></wifiConnectedAP>
<infraLedState>1</infraLedState>
<humanDetectAlarmState>1</humanDetectAlarmState>
</CGI_Result>With the command curl in a script in LUA in domoticz:
os.execute('curl "http://192.168.1.xx:xx/cgi-bin/CGIProxy.fcgi?cmd=getDevState&usr=xxxxx&pwd=xxxxx"')Would be really convenient to do some scenario in case of alarm.
