Script send value in a dummy captor : new problem...
Posted: Wednesday 06 March 2019 22:04
by samourai47
Hello everybody and sorry for my poor english...
I am on raspberry and i found this pyton script here (-> https://raspberrytips.nl/tsl2561-licht- ... pberry-pi/) for testing my TSL2561. It work's fine.... and i obtain in cmd 3 values
# TSL2561
import smbus
import time
# Get I2C bus
bus = smbus.SMBus(1)
# TSL2561 address, 0x39(57)
# Select control register, 0x00(00) with command register, 0x80(128)
#		0x03(03)	Power ON mode
bus.write_byte_data(0x39, 0x00 | 0x80, 0x03)
# Select timing register, 0x01(01) with command register, 0x80(128)
#		0x02(02)	Nominal integration time = 402ms
bus.write_byte_data(0x39, 0x01 | 0x80, 0x02)
time.sleep(0.5)
# Read data back from 0x0C(12) with command register, 0x80(128), 2 bytes
# ch0 LSB, ch0 MSB
data = bus.read_i2c_block_data(0x39, 0x0C | 0x80, 2)
# Read data back from 0x0E(14) with command register, 0x80(128), 2 bytes
# ch1 LSB, ch1 MSB
data1 = bus.read_i2c_block_data(0x39, 0x0E | 0x80, 2)
# Convert the data
ch0 = data[1] * 256 + data[0]
ch1 = data1[1] * 256 + data1[0]
# Output data to screen
print "Full Spectrum(IR + Visible) :%d lux" %ch0
print "Infrared Value :%d lux" %ch1
print "Visible Value :%d lux" %(ch0 - ch1)
Can i have some help to "modify" the script? I want to use in a dummy virtual captor and i don't know how to make that.... I wan't the "Full Spectrum(IR + Visible) :%d lux" %ch0, go in a txt dummy captor.
Thank's for your help
Re: Script send value in a dummy captor
Posted: Friday 08 March 2019 14:24
by samourai47
Well, no solution at this time.
I have added
import urllib
and
httpresponse = urllib.urlopen('http://192.168.0.120:8080/json.htm?type=command&param=udevice&idx=44&nvalue=0&svalue="str(ch0)"')
It's only txt ; "str(ch0)" who is send to the the dummy captor, not the value ch0
I dont know how to recover this value
Posted: Friday 08 March 2019 15:00
by jvdz
samourai47 wrote: Friday 08 March 2019 14:24
You need to concatenate the value... something like this?:
httpresponse = urllib.urlopen('http://192.168.0.120:8080/json.htm?type=command&param=udevice&idx=44&nvalue=0&svalue="'+str(ch0)+'"')
Jos
Posted: Friday 08 March 2019 16:04
by samourai47
Yes!!!!
Next work is to create a cron tab for running this script every minutes.....
I am too happy...
Posted: Monday 11 March 2019 11:00
by samourai47
Hello
Here the completed script that works on my raspberry p2. Thak's for your help
I have 2 dummy sensor
One is "Lux" (idx=45)
The other is Txt (idx=44) and receive the 3 data of the tsl2561
# TSL2561
import smbus
import time
import urllib
# Get I2C bus
time.sleep(0.5)
# ch0 LSB, ch0 MSB
# ch1 LSB, ch1 MSB
# Convert the data
# print "Full Spectrum(IR + Visible) :%d lux" %ch0
# print "Infrared Value :%d lux" %ch1
# print "Visible Value :%d lux" %(ch0 - ch1)
httpresponse = urllib.urlopen('http://192.168.0.120:8080/json.htm?type=command&param=udevice&idx=45&nvalue=0&svalue='+str(ch0)+'')
httpresponse = urllib.urlopen('http://192.168.0.120:8080/json.htm?type=command&param=udevice&idx=44&nvalue=0&svalue=Full Value: '+str(ch0)+'; Visible Value: '+str(ch0 - ch1)+'; Infrared Value: '+str(ch1)+'')
Output data to screen is desactivated. I need it only for the test
I create a crontab that send the data every minutes
Thank you for your help
Posted: Sunday 01 September 2019 15:20
by samourai47
Hello!!
Unfornutally i must rienstall raspian. I take the last buster full version. And the last domoticz version
I have a probleme with the script, who works perfectly until the software problems
When in run the script in command line the values are correctly print to the screen console, but for the domoticz i have this messages....
Can someone help me to understand and modifie the script?
Thank's
Full Spectrum(IR + Visible) :7813 lux
Infrared Value :4702 lux
Visible Value :3111 lux
File "tsl2561.py", line 38, in <module>
httpresponse = urllib.urlopen('http://192.168.0.120:8080/json.htm?type ... '+str(ch0)+'')
File "/usr/lib/python2.7/urllib.py", line 87, in urlopen
return opener.open(url)
File "/usr/lib/python2.7/urllib.py", line 216, in open
return getattr(self, name)(url)
File "/usr/lib/python2.7/urllib.py", line 353, in open_http
h.endheaders(data)
File "/usr/lib/python2.7/httplib.py", line 1038, in endheaders
self._send_output(message_body)
File "/usr/lib/python2.7/httplib.py", line 882, in _send_output
self.send(msg)
File "/usr/lib/python2.7/httplib.py", line 844, in send
self.connect()
File "/usr/lib/python2.7/httplib.py", line 821, in connect
self.timeout, self.source_address)
File "/usr/lib/python2.7/socket.py", line 575, in create_connection
raise err
IOError: [Errno socket error] [Errno 111] Connection refused
Re: Script send value in a dummy captor : new problem...
Posted: Sunday 01 September 2019 16:48
by jvdz
Last error line indicates that you do not have the access to the site.
Is 192.168.0.120 still the correct IP address?
Is this the Domoticz server and have you allowed the 192.168.0.* subnet access without password?
Jos
Posted: Sunday 01 September 2019 18:24
by samourai47
I found the error. i install domoticz only with ssl port. And in the domoticz.sh the standard port was at 0. i modify to 8080
And i dont know if it possible to configure the line with https
httpresponse = urllib.urlopen('http://192.168.0.120:8080/json.htm?typ............
in
httpresponse = urllib.urlopen('https://192.168.0.120:443/json.htm?typ
Thank you
