Energy Consumption based activites
Posted: Wednesday 06 March 2019 19:47
by FabianHD
Hello everyone,
After reading
https://www.domoticz.com/wiki/Capturing ... ua_Scripts, I am trying to implement an energy based action in Lua, but unfortunately I struggle to get the right commands for the current and the duration into Lua.
My idea behind is the following:
Once device (='Dishwasher') is turned on, it should check the used current, if this is lower than value x for a certain period of time, it should turn the device off again, at the moment, the only thing I have is the following:
if (devicechanged['Dishwasher'] == 'On') then
commandArray['Dishwasher']='Off'
Thanks for your support
Re: Energy Consumption based activites
Posted: Wednesday 06 March 2019 21:33
by EddyG
In the dzVents section are several scripts present.
It depends with what you measure the current and with what you want something to switch
I have a neo coolcam switch which also measures the currrent.
Posted: Wednesday 06 March 2019 21:37
by FabianHD
thanks for your feedback, I am using a Sonoff Pow to measure my power with.
Describing in simple words:
If Dishwasher is turned on and Energy-Consumption Dishwasher is < 10 Watt for more than 10 min then
Turnoff Dishwasher
Posted: Thursday 07 March 2019 13:14
by EddyG
Here are some scripts:
viewtopic.php?f=72&t=23798
I have a modified one for an Neo coolcam plug, which is a switch (plug) and a power measuring device. So 2 in 1.
If you use the Sonoff the same way you could use the script below, with thanks to the guys in the above link.
local USAGE_DEVICES = {
['Wasmachine kWh Meter'] = 'Wasmachine', -- You need to have a inline wall plug that measures energy,
['Wasdroger kWh Meter'] = 'Wasdroger', -- here you make the link between the energy device and the wall plug.
['Airco kWh Meter'] = 'Airco' -- Adjust to your needs. Between every line you need to add a ",".
local USAGE_SwitchTimeOutMinutes = {
['Wasmachine'] = 5, -- Here you define how long no power is used per device.
['Wasdroger'] = 6, -- The period is in minutes.
['Airco'] = 3 -- Adjust to your needs. Between every line you need to add a ",".
local USAGE_MaxWatt = {
['Wasmachine'] = 5, -- Here you define the maximum amount of power a device uses when it is in standby.
['Wasdroger'] = 5, -- Some devices uses a little amount of power. Test it and put here the slightly higher power usage.
['Airco'] = 5 -- Adjust to your needs. Between every line you need to add a ",".
local USAGE_Notify = {
['Wasmachine'] = 'Yes', -- In some cases you want to be notified when a device is turned on and off.
['Wasdroger'] = 'No', -- Adjust to your needs. Between every line you need to add a ",".
['Airco'] = 'Yes'
active = true,
-- active = false,
logging = {
level = domoticz.LOG_INFO, -- Uncomment to override the dzVents global logging setting
marker = 'POW'
devices = { -- Make sure that the devices are the same as above
'Wasmachine',
'Wasmachine kWh Meter',
'Wasdroger',
'Wasdroger kWh Meter',
'Airco',
'Airco kWh Meter'
data = { -- use exact device names to match USAGE_DEVICES
['Wasmachine kWh Meter'] = { history = true, maxMinutes = 6 },
['Wasdroger kWh Meter'] = { history = true, maxMinutes = 10 },
['Airco kWh Meter'] = { history = true, maxMinutes = 10 }
execute = function(dz, device)
-- local debug = true
local debug = false
if (USAGE_DEVICES[device.name] ~= nil) then
-- we have a usage sensor here
local switch = dz.devices(USAGE_DEVICES[device.name])
local history = dz.data[device.name]
local timeout = USAGE_SwitchTimeOutMinutes[USAGE_DEVICES[device.name]]
local watt = USAGE_MaxWatt[USAGE_DEVICES[device.name]]
if debug then
dz.log(switch.name .. " - Status: " .. switch.state .. " - Age: " .. switch.lastUpdate.minutesAgo .. " minutes")
dz.log("timeout = " .. timeout .. " - maxwatt = " .. watt .. " - current power: " ..device.usage .. " - Average: " .. dz.utils.round(history.avg()))
if switch.state == "On" then
history.add(device.usage)
if (history.avg() <= watt and switch.lastUpdate.minutesAgo >= timeout) then
dz.log("Switching " .. switch.name .. "Off")
switch.switchOff().checkFirst()
dz.data[device.name].reset()
-- device is a switch
local notify = USAGE_Notify[device.name]
if debug then
dz.log(device.name .. " notify = " .. notify)
if (device.state == "On" and notify == "Yes") then
dz.notify(
"ACTIVATE",
device.name .. " activated#I let you know when device " .. device.name .. " is turned off",
dz.PRIORITY_NORMAL,
dz.SOUND_SIREN,
{ dz.NSS_HTTP, dz.NSS_GOOGLE_CLOUD_MESSAGING }
elseif (notify == "Yes") then
dz.notify(
"DEACTIVATED",
device.name .. " is klaar.",
dz.PRIORITY_HIGH,
dz.SOUND_INTERMISSION,
Posted: Saturday 09 March 2019 0:05
by FabianHD
thank you very much, your scrip looks really great and it works perfectly!
One question for further understanding:
What is the difference between both time periods?
Posted: Saturday 09 March 2019 23:41
by felix63
The time period defined in USAGE_SwitchTimeOutMinutes is the amount of time that a machine has to report a power usage below the level defined in USAGE_MaxWatt. The time specified as maxMinutes in the data clause specifies the amount of historical data on kWh that needs to be kept. In order for the script to work the USAGE_SwitchTimeOutMinutes should be lower than maxMinutes. This because the script uses the historical data to determine the average usages.
Posted: Sunday 10 March 2019 12:07
by FabianHD
thank you, now I fully understood the script!
