problem adding/removing nodes via ozw panel
renevb
When i try to add or remove a node via the open z wave control panel in domoticz (latest beta's)the panel gets stuck and i dont get information that something is added or removed. When i press refresh the node is included or removed. When i press abort nothing happens and it seams that the panel is stuck. The problem is that it does not include nodes in secure mode at that point. If had this problem for sometimes and i am not sure when it started Anybody ever had the same problem.? I use an AEON Labs ZW090 Z-Stick Gen5 EU.
kimhav
- Domoticz version: 2023.2
Re: problem adding/removing nodes via ozw panel
Don't know whether you've solved this but agree that removing nodes is a pain from the OZW Control Panel. What I've on my side when I had the need to remove some nodes, which I recently had, I pulled the power on the the specific nodes that I wanted to remove and waited until the where reported dead and then used the remove function in the CP. Then it worked without any issues on my side.
When it comes to adding, I'm currently now adding by making use of the auto inclusion function which the Qubino has; meaning when they're powered on they'll be in inclusion mode for a short while. So in the OZW CP I choose to add a new node and then enable power to the Qubino which is automatic added and it works everytime.
When removing a Qubino for one reason or another I currently now always performs factory reset make sure that they're clean. Also, when adding Qubino's I'm using a test rig cable to ensure that I'm including them close to the RaZberry controller due to that zwave nodes doesn't make use of the mesh network when being added.
