[SOLVED] Uptime to variable
HansieNL
Post by HansieNL »
I have a script that is logging Domoticz uptime to a textdevice. Now I prefer to log the uptime to a user variable. Can someone tell me how to change the current script? Thanks in advance.
-- dzuptime.lua
-- Shows Domoticz Uptime in Dummy Text device
    on = {   timer  =   {"every minute"}},
    execute = function(dz)
        local uptimeTextDevice = dz.devices("Uptime")
        local days    = dz.startTime.daysAgo
        local hours   = dz.startTime.hoursAgo%24
        local minutes = dz.startTime.minutesAgo%60
 	uptimeTextDevice.updateText(days .. " dagen, " .. hours .. " uur en " .. minutes .. " minuten")
-- dzuptime.lua
-- Set Domoticz Uptime as UserVariable
        local uptimeUserVariable = dz.variables("Uptime")
 	uptimeUserVariable.set(days .. " dagen, " .. hours .. " uur en " .. minutes .. " minuten")
Blah blah blah
Re: [SOLVED] Uptime to variable
HansieNL wrote: Saturday 02 March 2019 20:28 I have a script that is logging Domoticz uptime to a textdevice. Now I prefer to log the uptime to a user variable. Can someone tell me how to change the current script? Thanks in advance.
Some other options..
-- dzuptime.lua
        local uptimeTextDevice      = dz.devices("Domoticz uptime")           -- define this as a virtual text device
        local uptimeString = days .. " dagen, " .. hours .. " uur en " .. minutes .. " minuten"
        uptimeTextDevice.updateText(uptimeString)
       -- define one or more of these variables and comment the lines you don't use
        dz.variables("uptimeString").set(uptimeString)                                                              -- define var as type string
        dz.variables("uptimeMinutes").set(dz.startTime.minutesAgo)                                                  -- define var as type integer
        dz.variables("uptimeHours").set(dz.startTime.hoursAgo)                                                      -- define var as type integer
        dz.variables("uptimeDays").set(dz.startTime.daysAgo)                                                        -- define var as type integer
        dz.variables("uptimeSeconds").set(dz.startTime.secondsAgo)                                                  -- define var as type integer
        dz.variables("uptimeMilliSeconds").set(dz.startTime.millisecondsAgo)                                        -- define var as type integer
        dz.variables("startTime").set(dz.startTime.rawTime:sub(1, -4))                                              -- define var as type time
        dz.variables("startDate").set(dz.startTime.day .. "/" .. dz.startTime.month .. "/" .. dz.startTime.year)    -- define var as type date
        dz.variables("startDateTime").set(dz.startTime.raw)                                                         -- define var as type string
