Noob: Can't get the constant values to work
Posted: Friday 01 March 2019 9:37
by Marque1968
I have a global_data via the gui:
-- global_data.lua
   helpers = {
      findInArray = function(searchvalue, checkarray)
         local foundvalue = false
    		for key,value in pairs(checkarray) do
    		    if (value == searchvalue) then
    		        foundvalue=true
         return foundvalue
      end,
      findInDeviceArray = function(domoticz, searchvalue, checkarray)
    		    if (domoticz.devices(value).state == searchvalue) then
    		        foundvalue=true
         return foundvalue
      end,
      findInVariableArray = function(domoticz, searchvalue, checkarray)
    		    if (domoticz.variables(value).value == searchvalue) then
    		        foundvalue=true
         return foundvalue
      end,
      -- Device ID's
      DID_radiation = 193,
      DID_radiationdisplay = 149,
      -- Variable ID's
      VID_proxM = 1,
      VID_proxN = 4,
      -- Global variables
      MY_CONSTANT = 100 -- doesn't have to be a function
The findIn... functions I have impemented in the system already, and work as expected, however not so for the constant variables. I have this script:
local idx_radiation = domoticz.helpers.DID_radiation
local idx_virtual = domoticz.helpers.DID_radiationdisplay
		devices = { idx_radiation },
	execute = function(domoticz, triggeredItem, info)
        domoticz.devices(idx_virtual).updateCounter(domoticz.utils.round(triggeredItem.radiation,0))
But the calling of these constant variables result in the following log entry:
2019-03-01 09:12:42.878 Status: dzVents: Error (2.4.14): ...icz/scripts/dzVents/generated_scripts/test radiation.lua:1: attempt to index field 'helpers' (a nil value)
(as you can see, I started from the example on https://www.domoticz.com/wiki/DzVents:_ ... _functions )
I also read there was a DATA section to the global_data.lua, but I do not want these values to be changed by functions in any other script (or even this one, for that matter).
Any input greatly appreciated.
Re: Noob: Can't get the constant values to work
Posted: Friday 01 March 2019 12:22
by waaren
Marque1968 wrote: Friday 01 March 2019 9:37 I have a global_data via the gui:
Your global_data is correct but you try to access the domoticz object in your script in an area where it is not accessible.
To retrieve the value from domoticz.helpers.DID_radiationdisplay, you will have to move the assign statement inside the execute = function part
like:
		timer = {"every minute"},
        domoticz.log("idx_virtual: " .. idx_virtual)
The other thing is that the term CONSTANT used in global_data could led you believe that it cannot be changed in your script. Which is not the case as you can see from this example: (Let it execute at least twice to see what happens)
	    domoticz.helpers.DID_radiationdisplay = "Not a real constant"
In fact Lua does not know a constant type as such. As explained here there is a (complicated) way to work around that but I never found a good reason inside the domoticz area to use that approach.
Posted: Sunday 03 March 2019 11:37
by Marque1968
So what I want (and think I need), is not possible?
I want a list of devices and variables, accessible by name, so when a power plug fails (which happened to me last week) and gets replaced by another power plug, I want to changed the value in the list of constants so ALL scripts who reference that power plug in any way, now use the new device.
And if those constants can be changed in an other script is not a real issue for me, as I won't do that, AND if the system resets it would refer to the original value again, which is not the case with the data section.
Posted: Sunday 03 March 2019 12:39
by Marque1968
I think I found a work around
I now created a lua file in my home directory:
var1=1
var2=2
var3=182
And added to the dzVents script:
dofile("/home/pi/Documents/scripts/vartest.lua")
local idxs_of_switch = {var3} --{182}
		devices = idxs_of_switch,
		if (triggeredItem.active) then
		    domoticz.helpers.zendTelegram(domoticz,"info\r\n Device on")
		    domoticz.helpers.zendTelegram(domoticz,"ALARM. Device is switched off !!!")
This does the trick:
HOWEVER
I am in a bit of doubt if this is fool proof. If the variable in the 'vartest' file is changed, how would domoticz know if it needs to trigger on a new value? Does it activate each and every script upon an event to check if the script needs to be executed? I would have thought it to be a set to a database trigger, but during my testing I could change the 'vartest' file without touching the dzvents script, and the triggers would react according to the new values. So I think I found myself a solution here...
Posted: Sunday 03 March 2019 21:19
by waaren
Marque1968 wrote: Sunday 03 March 2019 11:37 So what I want (and think I need), is not possible?
If the fact that they can be changed in other scripts is not an issue for you, it is possible and in fact you already did it. Just define them in global_data and use them as in my example.
Posted: Monday 04 March 2019 7:48
by Marque1968
Ok, didn't think of that. I had a seperate file, which was not accessable from the UI, so I could not alter it from a remote location. Your solution lets me alter the work-installation from the comfort of my couch at home :)
