Hi guys im hoping someone can point me in the right direction.
I want to control a dc motor. Just straight on off no speed control. Its a 3 v motor and will be on for about a second.
I plant to use it to drive the motor in my glade air freshener and discard the board that comes pre built with the unit.
My end goal is to activate via domoticz when im home only and times i can set from domoticz. Id also like to power it from the 3v battery’s inside but not sure how long it would last. Eventually id like to get the battery voltage sent back to domoticz too.
I think i could do this with a ESP-01 and a transistor but not sure on the best one to use. Would like to keep it as small as possible. Many thanks
Esp-01 motor control
kimot
- Domoticz version: v3.8153
Re: Esp-01 motor control
Load ESPeasy to your ESP and send commands from Domoticz to it.
You can use time scheduler for this switch.
From battery is not possible drive ESP for longer time.
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
1 x Shelly 1
1 x RFLink
4x Cam IPC-T240H
