I bought a smartwares cip-39218at outdoor cam at the action for 54 euro (dutch shop). I hoped to get the stream of the cam to use it in domotics. The default app of smartwares workes perfectly, but when I want to have the stream I cannot find it. I found on https://www.ispyconnect.com/man.aspx?n=SmartWares this camera, but only a snapshot version, but no stream. I tried all the other type smartware links also, but with no result. Has someone a tip to find the stream? Or does someone know the link of the stream?
Johan
Action: smartwares cip-39218at camera
1x RPi B+
1x RFXcom433e
KAKU: 1x APA3-1500R (3 switches), 4x AMST-606, 1x ASUN-650, 1x AFR-060, 1x AFR-100
ELRO: 4x AB400
ELRO: 4x COCO GDR2-1000R
Wether: 3x Xiron outdoormeters, Alecto 4500, Alecto 1700
Doorbells: 2x action
LG-tv, Yamaha-receiver
1x RFXcom433e
ELRO: 4x AB400
- Minglarn
- Domoticz version: v3.8153
Re: Action: smartwares cip-39218at camera
Hi!
I've have the SmartWares CIP-37186RT cam...
Did you find a way to get snapshots or videostream url?
Snapshot is working whithout any security:
http://ip-address/snapshot.jpg
I don't understand bubble but looks like he wants to save the file... and then nothing is happening:
http://ip-address/bubble/live?ch=0&stream=0
And most usefull, is with security, but that is hardcoded in the camera and not free. I tried several things, but cannot find the correct credentials:
rtsp://ip-address:80/ch0_0.264
1x RPi B+
1x RFXcom433e
ELRO: 4x AB400
1x RFXcom433e
ELRO: 4x AB400
- Domoticz version: 2020.2
Today bought a Smartwares camera CIP-37210AT a the Action shop to add this to domoticz.
After installation with smartphone you know the PASSWORD of the cam.
The factory site provides some information about the rtsp
https://support.smartwares.eu/nl/suppor ... c-mac-vlc-
username is default "admin" and the PASSWORD you choose with the installation.
My first step was to create a connection trough VLC.
rtsp://IPADDRESS:554/live/av0?user=admin&passwd=PASSWORD
The next step is to add this to my surveillance station
You can add this through a user defined type with steaming RTSP
The link here is a slightly different:
rtsp://admin:PASSWORD@IPADDRESS:554/live/av0?user=admin&passwd=PASSWORD
To add this Camera to Domoticz I can't say yet... working on it.
- Target OS: -
@bluemotion: How on earth did you get that thing to run in VLC?! I purchased the same type of camera (also Action shop ) and was hoping to use it with SplitCam. But for the life of me I can't figure out the Rtsp... So far I've come across a couple of rtsp's like the one you're using, but no succes. So I tried capturing the stream url by using TpacketCapture on my phone while connecting to the camera. No good, because it can't connect to the camera with TpacketCapture running. So I tried finding image files via Wireshark to see if that gives me any clue. No luck either.
So after a long struggle and eventually finding this post by googling the type number, I saw your message. And I used the rtsp link you mentioned. In VLC (just to be on the safe side)... I've used both my wifi as ethernet IP's, doublechecked them through the command prompt and in my internet settings, and used both my own password (as I put in that Homewizards camera app) as the standard password from this camera. I've reset it. I've removed it. I've reinstalled it. I have been fiddling for over an hour now and are getting really annoyed and desperate
What am I missing?! I feel like such an idiot!
VLC gives a "connection error" messagebox, for all varieties on the IPaddress I can think of.
Have you got any idea what I might be doing wrong? Or could you walk me step by step through the process you used to stream from the CIP-37210AT?
You would be a total hero <3
This works really well for me,walgreenslistens thank you! Facing same issue here. Help is appreciated.dewagt wrote: ↑Tuesday 26 May 2020 16:36 Snapshot is working whithout any security:
