Accessing Domoticz from 2 interfaces
Posted: Monday 18 February 2019 20:10
I’m trying to access the Domoticz Web Service (port 8080) on my Raspberry Pi via both of the following interfaces (which have static IPs):
Ethernet (eth0, 172.22.0.99, connected to a Netgear router).
Wi-Fi (wlan0, 172.24.1.1, providing an Access Point).
Currently, I can only access the web service if I connect to eth0 and gain an IP address 172.22.0.x.
If I connect to the Wi-Fi Access Point on wlan0 then I correctly acquire an IP Address 172.24.1.x, hence SSH works, but the web service is inaccessible (both http://172.22.0.99:8080 and http://172.24.1.1:8080).
I’ve been testing the above using a Windows 10 laptop. The actual problem is that I have a number of Arduinos which can connect to the Pi’s Wi-Fi Access Point (wlan0), but cannot then access the Pi’s Web Service. Hence instead I’m currently having to connect them via the Netgear router, and hence the Pi’s eth0. This is what I’m trying to avoid.
Aside: the Pi is also running:
OpenVPN, hence eth0 is bridged (br0, tap0).
A Wi-Fi sniffer (wlan1alfa, renameX).
172.22.0.100/102/106/113 examples of a working Arduinos
Any pointers very welcome…, thanks in anticipation
Geoff
Having created the following post (with lots of information about my setup):
https://unix.stackexchange.com/question ... -interface
I realised the issue might be specific to Domoticz.
I found a possible area for investigation:
https://unix.stackexchange.com/question ... -ssh-to-it
So I'm one step closer, note the "0.0.0.0:8080":
Geoff
Geoff
On my Pi, note the ":::8080":It can be the case that the webserver is listening only on localhost(127.0.0.1) instead of listening on all interfaces(0.0.0.0)Code: Select all
$ sudo netstat -taupen | grep LISTEN
A bit more investigation found the startup parameter '-wwwbind' in domoticz.sh:$ sudo netstat -taupen | grep LISTENCode: Select all
tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 0 15295 1847/smbd tcp 0 0 0.0.0.0:5901 0.0.0.0:* LISTEN 1000 11927 1437/Xtightvnc tcp 0 0 0.0.0.0:6001 0.0.0.0:* LISTEN 1000 11924 1437/Xtightvnc tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 0 14462 1154/dnsmasq tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14453 1143/sshd tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1000 15768 716/node-red tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 0 11708 903/mosquitto tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 0 15294 1847/smbd tcp6 0 0 :::139 :::* LISTEN 0 15293 1847/smbd tcp6 0 0 :::8080 :::* LISTEN 1000 4902627 25249/domoticz <<--- tcp6 0 0 :::53 :::* LISTEN 0 14464 1154/dnsmasq tcp6 0 0 :::22 :::* LISTEN 0 14455 1143/sshd tcp6 0 0 :::1883 :::* LISTEN 0 11709 903/mosquitto tcp6 0 0 :::445 :::* LISTEN 0 15292 1847/smbd tcp6 0 0 :::6144 :::* LISTEN 1000 4902635 25249/domoticz
DAEMON_ARGS="$DAEMON_ARGS -wwwbind 0.0.0.0"I still get the following:$ sudo netstat -taupen | grep domoticzCode: Select all
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 1000 21943078 27425/domoticz <<--- tcp 0 0 172.22.0.99:8080 172.22.0.102:52060 ESTABLISHED 1000 21949101 27425/domoticz tcp 0 0 172.22.0.99:8080 172.22.0.100:52135 ESTABLISHED 1000 21949100 27425/domoticz tcp 0 0 172.22.0.99:58528 172.22.0.99:1883 ESTABLISHED 1000 21946463 27425/domoticz tcp6 0 0 :::6144 :::* LISTEN 1000 21943086 27425/domoticz
I must be missing something...?http://172.24.1.1:8080/ (on laptop 172.24.1.42)Code: Select all
The connection has timed out The server at 172.24.1.1 is taking too long to respond. The site could be temporarily unavailable or too busy. Try again in a few moments. If you are unable to load any pages, check your computer's network connection. If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
Geoff
