Domoticz looks for config files in wrong paths
Posted: Monday 18 February 2019 17:48
I have installed Domoticz from Fedora's repository. Version: domoticz-4.9700-1.fc28.src.rpm.
It works for some months, but not everything works as it should.
Some problems are shown by log file:
1. I don't know why it wants to read configuration from /usr/bin/Config/ instead of /usr/share/domoticz/Config, where configuration files are located.
2. It tries to read /usr/share/domoticz/options.xml instead of /usr/share/domoticz/Config/options.xml, where the options.xml file is really located.
3. As you may also notice Plugin System doesn't start. No idea why. I believe it worked some time ago.
Have you got an idea what is wrong and how to fix it?
/etc/sysconfig/domoticz:
Service status:
Executable file:
/usr/bin/domoticz
Database files:
/var/lib/domoticz/domoticz.db
/var/lib/domoticz/domoticz.db-shm
/var/lib/domoticz/domoticz.db-wal
Service config files:
/etc/systemd/system/multi-user.target.wants/domoticz.service
Main installation folder:
/usr/share/domoticz
Error, Cannot find a path to the configuration files at /usr/bin/Config/, Using /etc/openzwave/ instead...
Info, Reading /etc/openzwave/options.xml for Options
Warning, Failed to Parse /usr/share/domoticz/options.xml: Failed to open file
Info, Options:
Info, appendlogfile: false
Info, associate: true
Info, assumeawake: true
Info, autoupdateconfigfile: false
Info, configpath: /etc/openzwave/
Info, consoleoutput: true
Info, customsecuredcc: <cut>
Info, drivermaxattempts: 5
Info, dumptriggerlevel: 4
Info, enablesis: true
Info, enforcesecurereception: true
Info, exclude:
Info, include:
Info, interface:
Info, intervalbetweenpolls: true
Info, logfilename: OZW_Log.txt
Info, logging: true
Info, networkkey: <cut>
Info, notifyondriverunload: false
Info, notifytransactions: false
Info, performreturnroutes: true
Info, pollinterval: 60000
Info, queueloglevel: 9
Info, refreshallusercodes: false
Info, reloadafterupdate: AWAKE
Info, retrytimeout: 10000
Info, saveconfiguration: true
Info, saveloglevel: 8
Info, securitystrategy: SUPPORTED
Info, suppressvaluerefresh: false
Info, userpath: /usr/share/domoticz/
Info, validatevaluechanges: true
Always, OpenZwave Version 1.5.0 Starting UpCode: Select all
WWW_PORT=8088
SSL_PORT=8443
SSLCERT="/var/lib/domoticz/domoticz.pem"
SSLPASS=""
SSLMETHOD=""
SSLOPTIONS=""
SSLDHPARAM=""
WWW_ROOT="/usr/share/domoticz/www"
DBASE="/var/lib/domoticz/domoticz.db"
USERDATA="/usr/share/domoticz/"
VERBOSE=1
LOG="/var/log/domoticz.log"
LOGLEVEL="0"Code: Select all
systemctl status domoticz.service
● domoticz.service - Domoticz Home Automation Server
Loaded: loaded (/usr/lib/systemd/system/domoticz.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2019-02-18 17:10:05 CET; 35min ago
Main PID: 12211 (domoticz)
Tasks: 19 (limit: 4517)
Memory: 25.2M
CGroup: /system.slice/domoticz.service
└─12211 /usr/bin/domoticz -www 8088 -sslwww 8443 -sslcert /var/lib/domoticz/domoticz.pem -sslpass -sslmethod -ssloptions -ssldhparam
-wwwroot /usr/share/domoticz/www -dbase /var/lib/domoticz/domoticz.db -userdata /usr/share/domoticz/ -verbose 1 -log /var/log/domoticz.log -loglevel 0
/usr/bin/domoticz
Database files:
/usr/share/domoticz
