Plans(Timers) switching ON/OFF on Selector Switch
Posted: Sunday 17 February 2019 14:25
by Kamil
Hello everybody,
is it possible to turn ON and OFF plans on selector switch using dzVents script?
For example I have one selector switch named "Heater" and I created plans for it.
On level "0" I want to have option that will disable all plans events on this switch and on level "10" it will enable them. The rest of levels will set temperature on it (temperature handling I already got).
For example:
		devices = {
			'Heater'
		if domoticz.device('Heater').switchSelector(0) then
		-- !!! and here I don't now how to appeal to plans !!!
Anyone can help?
Thank You in advance.
Re: Plans switching ON/OFF on Selector Switch
Posted: Sunday 17 February 2019 17:49
by waaren
Kamil wrote: Sunday 17 February 2019 14:25 is it possible to turn ON and OFF plans on selector switch using dzVents script?
can you elaborate a bit on the plans stuff and what you how you set the temperatures ?
Generic approach could be something like
return
			on		 =	{
							devices =   {
											'Heater'
		logging		 =	{
							level   =  domoticz.LOG_DEBUG,
							marker  =  "heater",
	execute = function(dz, device)
		heaterLevel = device.level
		local function logWrite(str,level)
			dz.log(tostring(str),level or dz.LOG_DEBUG)
        local function makeActionTable(actionsString)
            local t = {}
            local i = 0
            for str in actionsString:gmatch("[^|%s]+") do
                t[i*10] = str
                i = i + 1
            return t
        local actionTable = makeActionTable(device.levelActions)
		logWrite(device.name .. " level: " .. heaterLevel  .. "; level Name: " .. device.levelName .. "; level Action: " .. actionTable[heaterLevel])
		if	  heaterLevel == 0 then
			logWrite("Action for level " .. heaterLevel )
		elseif  heaterLevel == 10 then
		elseif  heaterLevel == 20 then
		elseif  heaterLevel == 30 then
Posted: Sunday 17 February 2019 18:39
by Kamil
Well...I'm using Bluetooth thermostats, so I'm connecting to them using external library and script.
For example:
script:///home/pi/eq3/eq3.exp XX:XX:XX:XX:XX:XX temp 5.0
Switch events.jpg (165.89 KiB) Viewed 1412 times
so temperature settings on thermostat is solved by this script calling from Selector Switch(dummy switch) settings.
Now I need just dzVents for disabling plans (Timers) on this switch (for example when I'm going to holiday). I do not want to unselect every single event in switch Timers.
So the question is how to call to Timers from Selector Switch in dzVents to turn them On and OFF with just one click (best way using one of Selector levels)?
Is my explanation clear?
Re: Plans(Timers) switching ON/OFF on Selector Switch
Posted: Monday 18 February 2019 1:45
by waaren
Yes is, clear.
create two extra levels in Heater device, named "Disable timers" and "Enable timers". These are used to trigger the actions from this script.
-- manageTimers
local httpResponses = "manageTimers"
    on      =   {
                    devices         =   { "Heater"   },
                    httpResponses   =   { httpResponses .. "*"   }
    logging =   {
                    level           =   domoticz.LOG_ERROR,
                    marker          =   httpResponse
    execute = function(dz, item)
        local function triggerJSON(url, response, delay)
            local response  = response or ""
            local delay     = delay or 0
            dz.openURL({    url = url,
                            method = "GET",
                            callback = response }).afterSec(delay)
        local function actOnTimers(rt,action,id)
            for key in ipairs(rt) do
                logWrite(rt[key].DeviceRowID)
                if tonumber(rt[key].DeviceRowID) == tonumber(id) then
                    triggerJSON(dz.settings['Domoticz url'] .. "/json.htm?type=command&param=" .. action .. "timer&idx=" .. rt[key].TimerID)
                    logWrite(action:gsub("^%l", string.upper) .. "d " .. rt[key].TimerTypeStr .." timer (id:" .. rt[key].TimerID .. ") for ".. rt[key].DevName,dz.LOG_FORCE )
        local function makeJSON(action,idx)
            return dz.settings['Domoticz url'] .. "/json.htm?type=schedules&filter=device",httpResponses .. "_" .. action .. "_" .. idx
        local function extractFromResponse(str)
            return str:match("_([^_]+)"), str:match("%d+") -- Extract action and idx from response
        if not item.isHTTPResponse then
            if item.levelName:find("able timers") then
                triggerJSON(makeJSON(item.levelName:lower():match("%a+"),item.id))    -- add action and device id to callback and get all deviceTimers
        elseif item.ok then                                      -- statusCode == 2xx
            logWrite(item.trigger)
            actOnTimers(item.json.result,extractFromResponse(item.trigger)) -- get action and device id from callback and act on it
            logWrite("Could not get (good) data from domoticz. Error (" .. (item.statusCode or 999) .. ")"  ,dz.LOG_ERROR)
            logWrite(item.data)
Re: Plans(Timers) switching ON/OFF on/by Selector Switch
Posted: Monday 18 February 2019 8:25
by Kamil
waaren wrote: Monday 18 February 2019 1:45 Yes is, clear.
-- manageTimers
    on      =   {
    logging =   {
                            method = "GET",
            logWrite(item.data)
Good morning Waaren!
Thank You for Your response!
Looks really promising. Can You show in Your code where is connection between script and those two levels in selector switch?
Or please give me small explanation what exactly happening here:
Thank You in advance!
Posted: Monday 18 February 2019 10:05
by waaren
If you are not yet familiar with dzvents then please look at the 10 lines using dzVents with Domoticz for an intro to dzVents and howto get this script active in domoticz.
The connection is in the line
So if the device is switched to either "Disable timers" or to "Enable timers" it will do the required.
rt: the table from domoticz with all timers for all devices
action: "enable" or "disable"
id: id of your selector device
Looping through the table this function looks for timer records with the id of your selector device and for every found one, it triggers an API to domoticz to enable or disable it.
