Piface 2 supported in Domoticz?
Posted: Wednesday 13 February 2019 20:17
by steve01
Trying to get Piface 2 to work on Raspi 2B.
According to the log, this hardware seems to be responding:
2019-02-13 18:49:47.568 Status: PiFace: Starting PiFace_SPI_Start()
2019-02-13 18:49:47.569 Status: PiFace: Found the following PiFaces:
2019-02-13 18:49:47.569 Status: PiFace: 0
2019-02-13 18:49:47.571 Status: PiFace: config file: Valid address: 0 , Pin: 1 and Port I Parameter: enabled , Value true
2019-02-13 18:49:47.571 Status: PiFace: config file: Valid address: 0 , Pin: 1 and Port I Parameter: pin_type , Value falling
2019-02-13 18:49:47.571 Status: PiFace: config file: Valid address: 0 , Pin: 1 and Port I Parameter: count_enabled , Value true
2019-02-13 18:49:47.571 Status: PiFace: config file: Valid address: 0 , Pin: 1 and Port I Parameter: count_update_interval_sec , Value 10
2019-02-13 18:49:47.575 Status: PiFace: Worker started...
However when using "add manual light/switch device" to make an input visible, in the hardware dropdown menu the Piface is not present.
Can it be that the Piface 2 is not supported yet?
Please your help
bye
Steve
Re: Piface 2 supported in Domoticz?
Posted: Wednesday 13 February 2019 22:09
by SweetPants
steve01 wrote: Wednesday 13 February 2019 20:17
Please your help
bye
Steve
In latest Beta it is
Posted: Thursday 14 February 2019 6:34
by Jan Jansen
Piface can also be used with the latest stable version.
