Fritzbox to send http command (via Domoticz?)
Posted: Wednesday 13 February 2019 11:17
I want my Fritzbox to open the door via an ESP EASY device. Basically what my plan ist to dial a specific number (internal) to make the Fritzbox send a command which finally sends a http command to a ESP Easy Device.
As I am not so familiar with the Fritzbox and the capability of VoiP commands, this might be possible via the callmonitor?
If Callmonitor is the only possibility then I will have a closer look. (ormaybe someone has already done it?
Maybe someone knows the fritzbox better than I do, then I would prefer a direct solution (Fritzbox - ESPEasy) (don“t think it works)
I know, one solution would be to install a DECT Plug and control it via Fritzbox. the DECT Plug will then switch a relay and opens the door...(Thats not smart at all
Maybe anyone has an idea....
Joachim
Joachim
