Issue with P1 Smart Meter
Posted: Tuesday 12 February 2019 21:02
Hi All.
I have a Issue with a lot of CRC Failed messages.
Version: CURRENT: 4.10373 (BETA) and 4.9700 (Stable)
Platform: Raspbian on Raspberry Pi 3
Plugin/Hardware: Philips Hue
Description: Issue with P1 Smat Meter
I have tried the following, but unfortunately I still get CRC notifications
1) reset the hardware device in domoticz (delete / reboot / readd)
2) reset the hardware dongle it self
3) upgrade to last BETA.
am i the only one with this problem?
Wouter.
2019-02-12 20:45:14.870 Status: P1 Smart Meter: Worker started...
2019-02-12 20:45:15.758 Status: P1 Smart Meter: Meter reports as DSMR 5.0
2019-02-12 20:45:16.186 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:16.793 P1 Smart Meter: Dismiss incoming - value is not delimited in line "1-0:1.8.2(000397.121"
2019-02-12 20:45:16.011 Status: P1 Smart Meter: Found gas meter on M-Bus channel 1
2019-02-12 20:45:18.185 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:19.192 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:20.185 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:21.181 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:22.181 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:24.180 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:25.194 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:26.190 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:27.179 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:28.185 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:28.936 P1 Smart Meter: Dismiss incoming - CRC value in message has trailing characters
2019-02-12 20:45:30.178 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:31.182 (Slimme meter) P1 Smart Meter (Power)
2019-02-12 20:45:31.199 (Slimme meter) P1 Smart Meter (Gas)
2019-02-12 20:45:32.793 P1 Smart Meter: Dismiss incoming - value in line "1-0:1.8.2(00039.129*kWh)" is not a number
2019-02-12 20:45:34.180 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:35.185 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:36.192 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:37.181 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:37.803 P1 Smart Meter: Dismiss incoming - value in line "1-0:1.8.2(00037.132*kWh)" is not a number
2019-02-12 20:45:39.193 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:40.179 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:40.978 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(231.*V)" is not a number
2019-02-12 20:45:42.000 P1 Smart Meter: Dismiss incoming - value in line "1-0:21.7.0(01&870*kW)" is not a number
2019-02-12 20:45:43.004 P1 Smart Meter: Dismiss incoming - value in line "1-0:22.7.0(00.00*kW)" is not a number
2019-02-12 20:45:44.041 P1 Smart Meter: Dismiss incoming - value in line "0-1:24.2.1(190212204509W)(00180.65�*m3)" is not a number
2019-02-12 20:45:44.810 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.2(00000.000*{Wh)" is not a number
2019-02-12 20:45:46.186 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:46.991 P1 Smart Meter: Dismiss incoming - value in line "1-0:31.7.0(008:A)" is not a number
2019-02-12 20:45:47.850 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(00.�00*kW)" is not a number
2019-02-12 20:45:48.796 P1 Smart Meter: Dismiss incoming - value in line "1-0:1.8.1(000402&772*kWh)" is not a number
2019-02-12 20:45:49.792 P1 Smart Meter: Dismiss incoming - value in line "1-0:1.8.1(0004p2.772*kWh)" is not a number
2019-02-12 20:45:51.183 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:52.180 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:53.181 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:54.186 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:55.000 P1 Smart Meter: Dismiss incoming - value in line "1-0:22.7.0(00&000*kW)" is not a number
2019-02-12 20:45:55.813 P1 Smart Meter: Dismiss incoming - CRC value in message has trailing characters
2019-02-12 20:45:57.186 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:58.192 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:45:59.179 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:46:01.186 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:46:02.193 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:46:03.178 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:46:04.186 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:46:05.192 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:46:07.186 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:46:10.189 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:46:11.177 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:46:12.184 P1 Smart Meter: Dismiss incoming - CRC failed
2019-02-12 20:46:12.807 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.1(00000.323*kWh)" is not a numberWouter.
