I see some people have had problems before. Added my phillips hue and it found the key fine, but no lights (or anything appears).
I've tried disabling and enabling again after a minute as suggested. The api username lets me access the JSON on the bridge fine.
Edit: Add new devices is enabled and works for the 433 devices.
Suggestions?
Version: 4.9700
Build Hash: a3a45906
Compile Date: 2018-06-23 14:24:51
dzVents Version: 2.4.6
Python Version: 3.4.2 (default, Sep 26 2018, 07:50:08) [GCC 4.9.2]
2019-02-12 19:50:43.078 Status: Philips Hue: Using poll interval of 10 secs.
2019-02-12 19:50:43.078 Status: Philips Hue: Worker started...
Full log---
2019-02-12 19:48:45.603 Status: Philips Hue: Worker stopped...
2019-02-12 19:49:04.007 (RFX433) Temp + Humidity (Living Room Temperature)
2019-02-12 19:49:04.026 (ZWave) Light/Switch (Alarm Type)
2019-02-12 19:49:04.029 (ZWave) Light/Switch (Alarm Level)
2019-02-12 19:49:04.030 (ZWave) General/Alarm (Alarm Type: Burglar 7 (0x07))
2019-02-12 19:49:04.032 (ZWave) Light/Switch (Burglar)
2019-02-12 19:49:05.543 (RFX433) Temp (Kitchen Temperature)
2019-02-12 19:49:46.537 (RFX433) Temp (Kitchen Temperature)
2019-02-12 19:49:57.005 (RFX433) Temp + Humidity (Living Room Temperature)
2019-02-12 19:50:27.545 (RFX433) Temp (Kitchen Temperature)
2019-02-12 19:50:50.002 (RFX433) Temp + Humidity (Living Room Temperature)
2019-02-12 19:51:08.538 (RFX433) Temp (Kitchen Temperature)
2019-02-12 19:51:43.015 (RFX433) Temp + Humidity (Living Room Temperature)
2019-02-12 19:51:49.707 (RFX433) Temp (Kitchen Temperature)
2019-02-12 19:52:05.757 OpenZWave: Domoticz has send a Switch command! NodeID: 15 (0x0f)
2019-02-12 19:52:05.766 (ZWave) Light/Switch (Desk Lamp)
2019-02-12 19:52:05.756 Status: User: Admin initiated a switch command (7/Desk Lamp/Off)
2019-02-12 19:52:30.714 (RFX433) Temp (Kitchen Temperature)
2019-02-12 19:52:36.012 (RFX433) Temp + Humidity (Living Room Temperature)
2019-02-12 19:52:44.472 (ZWave) Lux (Hall Light Sensor)
2019-02-12 19:52:44.496 (ZWave) Temp (Hall Temperature)
2019-02-12 19:53:03.858 (ZWave) Light/Switch (Alarm Type)
2019-02-12 19:53:03.861 (ZWave) Light/Switch (Alarm Level)
2019-02-12 19:53:03.862 (ZWave) General/Alarm (Alarm Type: Burglar 7 (0x07))
2019-02-12 19:53:03.864 (ZWave) Light/Switch (Burglar)
2019-02-12 19:53:11.548 (RFX433) Temp (Kitchen Temperature)
2019-02-12 19:53:29.012 (RFX433) Temp + Humidity (Living Room Temperature)
2019-02-12 19:53:52.539 (RFX433) Temp (Kitchen Temperature)
2019-02-12 19:54:06.801 (ZWave) Light/Switch (Alarm Type)
2019-02-12 19:54:06.804 (ZWave) Light/Switch (Alarm Level)
2019-02-12 19:54:06.805 (ZWave) General/Alarm (Alarm Type: Burglar 7 (0x07))
2019-02-12 19:54:06.807 (ZWave) Light/Switch (Burglar)
2019-02-12 19:54:22.009 (RFX433) Temp + Humidity (Living Room Temperature)
2019-02-12 19:54:33.548 (RFX433) Temp (Kitchen Temperature)
2019-02-12 19:54:49.888 (ZWave) Light/Switch (Alarm Type)
2019-02-12 19:54:49.890 (ZWave) Light/Switch (Alarm Level)
2019-02-12 19:54:49.891 (ZWave) General/Alarm (Alarm Type: Burglar 7 (0x07))
2019-02-12 19:54:49.893 (ZWave) Light/Switch (Burglar)
2019-02-12 19:55:14.541 (RFX433) Temp (Kitchen Temperature)
2019-02-12 19:55:15.005 (RFX433) Temp + Humidity (Living Room Temperature)
2019-02-12 19:55:55.550 (RFX433) Temp (Kitchen Temperature)
2019-02-12 19:56:08.004 (RFX433) Temp + Humidity (Living Room Temperature)
2019-02-12 19:56:36.719 (RFX433) Temp (Kitchen Temperature)
2019-02-12 19:57:01.017 (RFX433) Temp + Humidity (Living Room Temperature)
2019-02-12 19:57:17.713 (RFX433) Temp (Kitchen Temperature)
2019-02-12 19:57:54.015 (RFX433) Temp + Humidity (Living Room Temperature)
2019-02-12 19:57:58.545 (RFX433) Temp (Kitchen Temperature)
2019-02-12 19:58:39.538 (RFX433) Temp (Kitchen Temperature)
2019-02-12 19:58:47.014 (RFX433) Temp + Humidity (Living Room Temperature)
2019-02-12 19:58:49.101 (ZWave) Light/Switch (Alarm Type)
2019-02-12 19:58:49.103 (ZWave) Light/Switch (Alarm Level)
2019-02-12 19:58:49.104 (ZWave) General/Alarm (Alarm Type: Burglar 7 (0x07))
2019-02-12 19:58:49.107 (ZWave) Light/Switch (Burglar)
2019-02-12 19:59:20.549 (RFX433) Temp (Kitchen Temperature)
2019-02-12 19:59:40.012 (RFX433) Temp + Humidity (Living Room Temperature)
Phillips Hue not adding devices
AndrewHolding
AndrewHolding
Re: Phillips Hue not adding devices
Still broken in stable. Fixed by updating into the current beta.
arthur
Thanks, that fixed for me too.
