dio chacon 54514
Posted: Monday 11 February 2019 17:54
by opartex
I'm a newbie to Domoticz, so please bear with me
I installed DOMOTICZ on a raspberry pi 2 I had left unused.
I plugged a RFXCOMXL on a usb slot.
I manually added a switch with
Hardware : RFXCOMXL,
Switch type : Dimmer,
Type : AC,
ID : I didn’t change it since it’s the first thing I do on DOMOTICZ
Then I pressed TEST… but nothing happened !
And I tried and tried, I moved the rpi closer to the switch… nothing worked !
HELP !
Thanks for your help.
Re: dio chacon 54514
Posted: Monday 11 February 2019 18:24
by emme
try by add the switch this way:
go to Switch panel
select LEARN LIGHT/SWITCH button
Activate your switch
the learn process should complete and you should get the new switch
Posted: Monday 11 February 2019 22:23
by opartex
Hello emme,
I can't activate the swiitch since this device has no button on it.
Posted: Monday 11 February 2019 23:21
by Lebo2d9
Hi ,
the dio 54514 is working on 868 mhz, is your rfxcom aslo a 868 mhz version?
Kind regards
Koen
Posted: Tuesday 12 February 2019 11:02
by opartex
I checked on chacon's website, they say it's 433MHz.
Where did you read it's 686 ?
Thanks for your help Lebo2d9.
Posted: Tuesday 12 February 2019 22:41
by Lebo2d9
Hi Opartex,
I saw it on the website of conrad
https://www.conrad.be/p/draadloze-knop- ... term=95895
on the website of chacon they are talking about 433 MHZ
https://www.chacon.be/nl/verlichting/11 ... 45156.html. On a picrure on the conrad website there is a close-up of the dimmer and there it is indicated 433 MHz.
Posted: Tuesday 12 February 2019 23:03
by Lebo2d9
I think have to created a switch manualy. For hardware you take the hardware name you used for your rfxcom reciever, select dimmer for type, type is X10, house and unit code you can take what ever you want, as long they are unique.
Then you push the small button (leaning) on the dimmer and then you click test.
I don't own a dimmer but i have several switches. I think i added them this way.
I found also on a french forum a workaround using the remote control
http://easydomoticz.com/forum/viewtopic.php?t=2056
Kind regards
Koen
Posted: Thursday 14 February 2019 22:54
by opartex
I Will try with X10 Protocol and I'll let you know.
Posted: Friday 15 February 2019 9:00
by b_weijenberg
DIO Chacon with address code wheels is an ARC device and with automatic coding is an AC device.
Posted: Saturday 16 February 2019 9:03
by opartex
Hello and thank you for your reply b_weijenberg.
I tested AC, ARC and X10 but nothing works !
When I push test, lights are blinking on the RFXcom, but nothing changes on the DIO chacon...
Any idea ?
Posted: Saturday 16 February 2019 9:39
by b_weijenberg
Please test with RFXmngr:
Is the DIO remote received if you enable AC and ARC?
If you don't have a DIO remote pair the module using Lighting2 - AC and select (do not enter) a random ID and Unit code
Posted: Saturday 16 February 2019 10:05
by Lebo2d9
Do you set the DIO in learn mode?
Posted: Monday 18 February 2019 11:18
by opartex
Lebo2d9 wrote: Saturday 16 February 2019 10:05
yes I did
Posted: Monday 18 February 2019 11:26
by Lebo2d9
Do you have a remote control for the dimmer?
