Spirit Z-Wave Plus adjusting temperature too often
Posted: Saturday 09 February 2019 9:53
by Fooneen
I'm using Domoticz to manage a Eurotronic Spirit Z-wave Plus. I have setup multiple blocklies to control the comfort temperature during the day, and switch this between 15 and 20 degrees at different times and days.
This is working correctly, and I can see both on the display and in Domoticz that the setting is indeed set at the right values.
The problem I'm having is that the Spirit is adjusting the valve too often, which drains the battery far too much. Currently I can hear it changing the valve at a rate of once every 1-3 min. (You hear the small electromotor buzzing) This is far too often and drains the battery too much. It only takes about a month now before it is drained.
Below are the settings/values in the Open Z-wave control panel. I'm using a modified xml file to get Domoticz to recognize the Spirit which I found somewhere on this forum. Its attached aswell.
Any idea why this might be happening? Is it the build-in temperature control of the Spirit conflicting with the values pushed from Domoticz?
I'd say I just need to adjust the update rate somewhere to maybe once every 15 min.
The device is connected to the network most of the time, but once in a while loses connection and then reverts back to just 20 degrees all the time. That doesnt seem to be the problem because this occurs when it is connected.
Regards,
Fooneen
Re: Spirit Z-Wave Plus adjusting temperature too often
Posted: Sunday 10 February 2019 11:50
by EddyG
This is not the current xml file, at least not in my latest beta version of Domoticz.
Posted: Sunday 10 February 2019 12:04
by Fooneen
I know, I tried the one included in the stable version but that one didn't work. Changing the temperature did not update the spirit itself. This XML is one coming from another user here on this forum and does update the temperature.
If there is an incorrect setting in there leading to too frequent updates, I don't know. Might be possible.
Posted: Sunday 10 February 2019 13:10
by EddyG
So better to upgrade to beta, because I know for sure that it works. I have 3 Spirits working correctly.
One is working for almost half a year and still is at 85% battery.
