Eurotronic Spirit Z: Change Thermostat Mode
KaeptnM
Post by KaeptnM »
Hey again everybody!
I'm new but I'm getting better here and I'm trying and trying but theres a problem, that I can't handle with. So please do not be so strict to me, I'm still at the very beginning ;)
I'm operating a Synology DS218+ with an Aeotec Z-Stick and included successfully four Eurotronic Spirit Z. I can control them in nearly every way I want - except the Thermostat Mode.
The Thermostat Mode contains following Functions:
- Off
- Heat
- Heat Economy
- Full Heat
- Manual
I am able to set the mode manually on domoticz/utility and it's also accepted by the device, but I'd like to create some switches and/or events that use this feature.
I'm really not good at programming like lua or something else, so I tried to create something under Blockly.
But Blockly says following:
Does anyone know, what I can do to get the Thermostat Mode easy switchable? Is it possible without programming, or do I have to learn lua?
Thanks a lot in advance!
Best regards,
Marius
jureko
Re: Eurotronic Spirit Z: Change Thermostat Mode
Post by jureko »
Hey,
I also have a problem with that, but I did not know what was going on. I have similar to yours hardware configuration.
It's good that you pointed out that this block is read-only.
It looks like control "Thermostat mode" can be only by LUA or dzevents, but I do not know much about it.
Here I found an example:
https://www.domoticz.com/forum/viewtopi ... it#p206279
Maybe you found another solution?
jureko
Solderbro
Domoticz version: 2020.1
Post by Solderbro »
Hello
Same here, have 4 of these thermostats. The only way to use them is a timed table for the heat setpoint, so i change the value in the setpoint for the temperature. Don't know what the furnace and heat-eco setpoint is for.
Everything else seems to be ignored by the Spirit, glad that their config is working.
Solderbro
Raspi 3B+RTC, SSD 128GB, Aeotec Gen5, Eurotronic SpiritZ, Fibaro FRGBW, Zipato PIR, Everspring AN180, Neo Coolcam Plug, Fibaro FGMS, Neo Coolcam Doorsensor, Popp Z-Weather
EddyG
Post by EddyG »
Just my dzVents example for the Attic.
It (re)set the setpoint every time the script is called (twice a day)
At the morning it sets the temperature to 21 degr. (Heat) and set the temperature to 16 degr. (Heat Eco) at night.
        active = true,
                timer = { 'at 08:01 on mon, tue, wed, thu, fri',
                          'at 08:31 on sat, sun',
                          'at 20:01' }
        execute = function(domoticz)
                local t = domoticz.time
                if (t.matchesRule('at 08:01 on mon, tue, wed, thu, fri')) then
                        domoticz.devices('Zolder Level').switchOn()
                        domoticz.devices('Zolder Thermostat Mode').updateMode('Heat')
                elseif (t.matchesRule('at 08:31 on sat, sun')) then
                elseif (t.matchesRule('at 20:01')) then
                        domoticz.devices('Zolder Thermostat Mode').updateMode('Heat Eco')
                domoticz.devices('Zolder Heat').updateSetPoint(21)
                domoticz.devices('Zolder Heat Eco').updateSetPoint(16)
Solderbro
Post by Solderbro »
After some mind works :lol: i did this solution that saves battery and utilize blockly.
The first blocky checks outer temperature from my weather station and marks that in a variable.
For every room with z-wave heating regulator (Eurotronic spirit here) the blockly checks if heating is required and used a timed scheme then.
Further idea is to use the summerbreak variable as away switch, while holidays ;)
Solderbro
samuelAN
Post by samuelAN »
I have also 5 spirit valves. I use blockly to control them without changing the thermostat mode. During night or when I am not at home, I set the set point to a low value (17deg for example), in normal heat mode.
But I think that it is not the right way to operate these valves. I have the impression that when the set point is largely lower than the measured temperature, the algorithm inside the valves continue to integrate this negative error between the two values. Then, when a normal temperature is set (ie 21 or 22deg), the valves takes some pair of hours in order to reach the correct set point and sometimes with a static error of approx 0.5 to 1 deg.
Has someone the same experience?
I am running 0.16 application version for the valves. Which I think is the latest one.
samuelAN
Post by samuelAN »
I will do some tests but I have also noticed that when working in heat mode, the value of valve opening percentage seems to be incoherent wrt real valve opening...
jursat
Domoticz version: 2023.2
Post by jursat »
Maybe it will help someone, I use the system manufacturer to open the heads to 30% according to the need for heating.
I set the temperature using virtual variables
1. Create variables
2. Create a temperature table in Virtual switch
Set timers for change temperature
3. Create a command to turn on the valve
Valve opening ON
http://127.0.0.1:8084/json.htm?type=com ... &passcode=****
ID 120 is The boiler relay switch (Fibaro GBS222)
4. Create a selector to switch the valve mode
ID 131 is Hala Thermostat mode
5. Create a block diagram for each head (example for Hala)
On Heating Hala
Off Heating
6. General view
