Page 1 of 2
Zigate and Xiaomi temp/hum/baro sensors adjustment of temp
Posted: Tuesday 05 February 2019 18:06
by mcmikev
I am trying to adjust the values of my sensors in domoticz with -0.2 C on the TH sensors but that does not work.
Is this all related to this?
https://github.com/domoticz/domoticz/is ... -441357383
Or had this a different reason perhaps?
Re: Zigate and Xiaomi temp/hum/baro sensors adjustment of temp
Posted: Tuesday 05 February 2019 18:10
by pipiche
This is a problem related to Domoticz and the Python Plugin Framework. Indeed same problem as https://github.com/domoticz/domoticz/is ... -441357383 and unfortunately the Domoticz owner has closed the issue !
Attached is a short plugin to duplicate the problem.
Posted: Tuesday 05 February 2019 18:42
by mcmikev
What a shame. I thought that i was giving the wrong values but it just cannot be done this way
Posted: Tuesday 05 February 2019 18:53
by pipiche
@mcmikev I fully share your view. I'm very sad. I'm not expert enought in CC+ to fix that problem in Domoticz and it looks like nobody wanted to make it.
Here is the work I started , but was not success to finish: https://github.com/domoticz/domoticz/pull/2899
Posted: Thursday 14 February 2019 17:59
by mcmikev
Damn. Really miss this option
Xiaomi sensors are a bit “high” on temp Reading so adjusting with -0.5 or -1.0C would be great.
I turn off/on my heating with these readings.
Now it feels a bit cold because of the 1 degree difference.
Posted: Thursday 14 February 2019 19:18
by pipiche
I'll see if I can do something at the plugin level to compensate it.
Posted: Thursday 14 February 2019 22:08
by pipiche
If you switch to pre-4.1 branche . The adjustement of Temperature Sensor works. You need to have a beta version of Domoticz > 4.10355
In case you are on stable branche, please read with attention the file 00-UPGRADE-FROM-STABLE-4.0
Posted: Thursday 14 February 2019 22:53
by mcmikev
Great news !! Thank you.
Just did a git pull on the pre-4.1 branche and updated the xiaomi sensors (hum/temp/baro) with -0.3 and -0.5 degrees.
Hope to see the next update that the temp is "down"
Posted: Thursday 14 February 2019 23:00
by pipiche
Did you check that you have Domoticz Beta > 4.10335 ?
Posted: Thursday 14 February 2019 23:03
by mcmikev
i run v4.10419 so that is fine (build from source)
Posted: Thursday 14 February 2019 23:04
by mcmikev
domoticz framework change???
Posted: Thursday 14 February 2019 23:22
by pipiche
Yes, and no. I make a workaround in the plugin, but I needed to get access to new parameter now available via the Framework ;-)
So it should work ;-)
Posted: Thursday 14 February 2019 23:28
by pipiche
In any case, let me know the results
Posted: Saturday 16 February 2019 20:17
by mcmikev
It seems to work however there is a new strange thing now.
All of a sudden the temp reading goes haywire and is very long.
Not constant the same sensor it comes and goes.
Did a new pull just half an hour ago.
Posted: Saturday 16 February 2019 20:28
by pipiche
Just fixed it. So better that you redo the git pull, restart.
Could you let me know what was your adjustement value ? I beleive -/+ xx.yy
Posted: Saturday 16 February 2019 20:29
by mcmikev
I adjusted -0.3 and -0.5
Posted: Saturday 16 February 2019 20:36
by pipiche
So indeed , now I'm rounding the result of the adjustement
Posted: Saturday 16 February 2019 21:48
by mcmikev
Looks good so far. Thx
Posted: Saturday 16 February 2019 21:55
by pipiche
BTW, I have also enable adjustement on Baro
Posted: Monday 04 March 2019 16:45
by mcmikev
I have tried the temp adjustment on the THB devices that are created and updated the most due to barometric changes, but the THB devices are not using the offset.
The TH devices are, but the THB not. Temp, Humi,Baro can this be applied as well please???
