Which time triggers occur ?
Posted: Saturday 02 February 2019 10:12
by romeo
I need different time triggers rules for each month.
	    timer = {
	     -- For Open door
	    'at 06:30',
	     -- Close Door
	    '5 minutes after sunset on */1',
            '10 minutes after sunset on */2',
            '12 minutes after sunset on */3, */4',
            '15 minutes after sunset on */5',
            '17 minutes after sunset on */6, */7',
            '20 minutes after sunset on */8',
            '16 minutes after sunset on */9',
            '12 minutes after sunset on */10',
            '7 minutes after sunset on */11',
            '5 minutes before sunset on */12'
 	if (item.isTimer) then
 		Here, How to check what trigger rule is performed ??
How to know the time trigger performed ?
Thanks in advance,
Re: Which time triggers occur ?
Posted: Saturday 02 February 2019 10:26
by waaren
romeo wrote: Saturday 02 February 2019 10:12 I need different time triggers rules for each month.
Try this,
	    timer = {
                     -- For Open door
                    'at 06:30',
                     -- Close Door
                        '12 minutes after sunset on */3',
                        '12 minutes after sunset on */4',
                        '17 minutes after sunset on */6',
                        '17 minutes after sunset on */7',
            -- Here, How to check what trigger rule is performed ??
            domoticz.log("triggered by timer rule " .. item.trigger,domoticz.LOG_FORCE )
Posted: Saturday 02 February 2019 13:11
by romeo
Thanks waaren, it works great !!
Now, I have to find the right pattern for time trigger rules expression
My goal is to know if I have to close or open the door according to the timer rule
For opening, I just test with if(item.trigger == 'at 06:30)' then => Open
All time rules "XX minutes after sunset on XX" are for closing the door
For closing, if(item.trigger.match(XX minutes after sunset on XX) => Close
Other question !
Can I put time triggers rules as variable ??
return{
local TIME_OPEN = 'at 06:30'
local TIME_CLOSE = ?????
	    timer = {
	       TIME_OPEN,        -- For opening
	        TIME_CLOSE	 -- For closing
TIME_CLOSE should be
but that doesn't work !!
Posted: Saturday 02 February 2019 17:26
by waaren
romeo wrote: Saturday 02 February 2019 13:11 Other question !
Try this
local timeOpen           = 'at 06:30'
local times              =  {   timeOpen,
                                '5 minutes before sunset on */12',
	    timer = times
            if item.trigger == timeOpen then                                -- Here, How to check what trigger rule is performed ??
                domoticz.log("Should  open",domoticz.LOG_FORCE )
                domoticz.log("Should  close",domoticz.LOG_FORCE )
Posted: Sunday 03 February 2019 12:11
by romeo
Thanks again waaren.
My script is on the good way.
