Virtual thermostat with nominal, minimum and maximum
Morfeus
Post by Morfeus »
Hi evrybody,
I looking for solution for virtual thermostat with nominal, minimum and maximum points.
Before start fun with domoticz I had normal thermostat where can put set nominal temperature for example 21 degree and inside was calculated minimum temperature for example 20.5 degree where in this point was turn on heaters and after getting 21.5 degree heaters was turn off.
This solution will be for avoid too often turn on and turn off heaters.
I tried use blockly solutions but there not exist mathematical signs where I can add some value to the nominal point.
I would be very grateful for your help! :)
jake
Re: Virtual thermostat with nominal, minimum and maximum
Post by jake »
Morfeus wrote:Hi evrybody,
Check out the SVT, the software virtual thermostat plugin for domoticz. Much more precise in heating your home.
