Domoticz events have delay
Posted: Monday 28 January 2019 10:27
by pfloryann
I use Zigate and motion sensors for switch on the lights with domoticz blockly...but i have 2-3 seconds delay between the moment when i get in the room and lights on. I have same problem with LUA script...when i press the wireless button he turn on the lights after ~2 seconds.
Before to use Raspberry pi with Zigate i had Xioami Hub and I did not have delay.
I use now Domoticz 4.1 and zigate plugin beta version and Raspberry Pi 1 B...it can be from Raspberry Pi because is old model with 700mhz Cpu and 512 ram ?
How can I fix the delay because 2 seconds or more some time is a pretty much?
Re: Domoticz events have delay
Posted: Saturday 02 February 2019 22:40
by Thorgal789
You can try too with domoticz + Xioami hub (if you have the good one), it will help you to find the weak link.
If you enable log, you can see when the button is pressed and when the command go to the bulb, check the timestamp.
