Is dzVents that heavy on the CPU?
Posted: Sunday 27 January 2019 17:33
by quiptix
Maybe this is already discussed however since temperature is a common word in Domoticz-world, so I will (re)try again:
When I started with a LUA and soon converted it to a dzVents timer event the load on the CPU and temperaure of the CPU significantly raised from 45 celsius to 58 celsius and the CPU went from 4% to 15%.
One event runs every 5 minutes and one event runs every 24 hours on a specific time. Is this a common raise of used resources with LUA and/or dzVents?
It runs on a RPI 3B+
Any thoughts on this?
Vincent
- Naamloos.jpg (8.1 KiB) Viewed 928 times
Re: Is dzVents that heavy on the CPU?
Posted: Monday 28 January 2019 0:29
by waaren
quiptix wrote: Sunday 27 January 2019 17:33
When I started with a LUA and soon converted it to a dzVents timer event the load on the CPU and temperature of the CPU significantly raised from 45 celsius to 58 celsius and the CPU went from 4% to 15%.
any thoughts on this?
The percentage rise of CPU% is about the same as I measure when I activate dzVents on top of the event system on domoticz V4.10364. There is certainly some overhead in using dzVents compared to Lua if you use only a few scripts. The good thing is that the rise in CPU% is not lineair to the amount of scripts in use.
I have about 60 dzVents scripts active in a mix of device, timers, uservariables and httpResponses types on a RPI3 (debian stretch) with about half of them with debug logging continuously switched on and my measured CPU usage is about the same as what you see with two scripts. What can cause quite a heavy load on your system is a script with a syntax error in it, DzVents will then flood the domoticz log with messages.
Hope this clarifies
Posted: Tuesday 29 January 2019 1:32
by quiptix
It clarifies some. Is there a difference between device triggered scripts or timer triggered scripts?
Posted: Tuesday 29 January 2019 12:55
by waaren
quiptix wrote: Tuesday 29 January 2019 1:32
dzVents uses a different mechanism than domoticz Lua for this. The scripts can be a combination of device triggered and time triggered (and other triggers).
Time triggered can be every minute but also once a year and more or less the same can be true for devices and variable triggered scripts. My P1 device triggers a script every 10 seconds and I also use a script triggered by a uservariable that I only use once a month at most.
The evaluation of these triggers takes some cycles but not many and even less in the latest Beta (V4.10365) due to an improved algorithm for scanning the directory's.
As always YMMV.
Posted: Sunday 03 February 2019 23:28
by quiptix
Thanks. As I like to keep it stable I will wait for the next stable release and try again.
