My Router Hangs :(
Posted: Thursday 24 January 2019 10:52
Ciao,
My DDWRT sometimes hangs without an apparent reason (probably it reaches the max connections without closing them... )
so Instead of schedule a reboot I want to manage a reboot on demand.
The router itself has a whatchdog deamon, but since it hangs... it is quite useless!
So I decide to setup a workaround to check connectivity and taka action if needed.
The requirements are:
- A ping Hardware and device (I use 8.8.8.8 to check internet connectivity)
- A plug (I use ZWave, but it could be a GPIO with a rele or whatever you want, but NOT a wifi/network device!!)
the scripts runs once a hour anche check the ping device...
if it is off for more that 5 minutes then it means internet in unreachable due to the router, so let's reboot it.
It does this for max 3 times, then, as soon as the network is back reachable, it reset the counter.
Hope you will find this interesting:
not yet tested....
I'm at work right now and my router.... well... yes... it hanged this noght!
local maxRetry = 3 -- Max Retries before quit rebooting the router
local waitSec = 30 -- Seconds to wait before powering back up the router
local routerPingDev = 'PING_ROUTER' -- Router Ping Device (see Ping Hardware)
local routerPlugDev = 'PLUG_ROUTER' -- Router Plug Device
timer = {'Every 60 minutes'}
data = {
actRetry = { initial = 0 }
execute = function(dz)
local rtrActive = dz.devices(routerPingDev)
local rtrDevice = dz.devices(routerPlugDev)
if rtrActive.state == 'Off' and rtrActive.lastUpdate.minutesAgo >= 5 then ' Reboot
dz.data.actRetry = dz.data.actRetry + 1
if dz.data.actRetry <= maxRetry then
dz.notify('Rebooting the router', 'Looks like LAN/WAN are unreachable... rebooting the router for the '..dz.data.actRetry..'time[s]')
rtrDevice.switchOff()
rtrDevice.switchOn().afterSec(waitSec)
elseif rtrActive.state == 'On' and dz.data.actRetry ~= 0 then
dz.data.actRetry = 0
}I'm at work right now and my router.... well... yes... it hanged this noght!
