Default python script does not work
Posted: Thursday 24 January 2019 10:34
Version: 4.10179
Build Hash: f0985571
Compile Date: 2018-11-07 15:30:43
dzVents Version: 2.4.7
Python Version: 3.6.5 (default, Aug 22 2018, 14:21:14) [GCC 6.4.0]
From the webpage I have added a new python script and even the default script that is automatically created does not work.
This is the script:
Domoticz passes information to python scripts through global variables and the
domoticz python module
The global variables in the script are:
* changed_device: the current device that changed (object of Device)
* changed_device_name: name of current device (same as changed_device.name)
* is_daytime: boolean, true when it is is daytime
* is_nighttime: same for the night
* sunrise_in_minutes: integer
* sunset_in_minutes: integer
* user_variables: dictionary from string to value
A Device has a number of attributes and methods
The attributes are:
* id
* name
* type
* sub_type
* switch_type
* n_value
* n_value_string
* s_value
* last_update_string
* last_update: datetime object
The methods are:
* def last_update_was_ago(self, **kwargs):
Arguments can be: days[, seconds[, microseconds[, milliseconds[, minutes[, hours[, weeks]
* def is_on(self):
returns True when device is on
* def is_off(self):
returns True when device is ooff
* def on(self, after=None, reflect=False):
turns device on, after is optional and are the number of seconds after which
to turn the device on.
If reflect is True, a next call to is_on will return True, while normally
domoticz will first have to go through possible script before turning it on
def off(self, after=None, reflect=False):
simular to on()
uservariables and uservariables_lastupdate are arrays for all user variables:
uservariables['yourvariablename'] = 'Test Value'
uservariables_lastupdate['yourvariablename'] = '2015-12-27 11:19:22'
other useful details are contained in the following global variables:
* is_daytime
* is_nighttime
* sunset_in_minutes
* (TODO) security
TODO: wiki page
Compare to Lua, instead of filling a commandArray, you change the status of a
device by calling device.on() or device.off()
TODO: setting variables
Calling Python's print function will not print to the domoticz console, see below
import domoticz
import random
print ("This will only show up in the shell where you start domoticz");
domoticz.log("Hi Domoticz!")
domoticz.log("The device that got changed is: ", changed_device_name)
# changed_device.name is the same string
for name, device in domoticz.devices.items():
domoticz.log("device", name, "is", "on" if device.is_on() else "off")
if device.is_off():
domoticz.log("could turn it on in 3 seconds")
#device.on(after=3)
for name, value in user_variables.items():
domoticz.log("var", name, "has value", value)Code: Select all
2019-01-24 10:29:44.279 Error: EventSystem: Failed to execute python event script "script_device_python"
2019-01-24 10:29:44.279 Error: EventSystem: Traceback (most recent call last):
2019-01-24 10:29:44.279 Error: EventSystem: File "<string>", line 67, in <module>
2019-01-24 10:29:44.279 Error: EventSystem: File "/config/scripts/python/domoticz.py", line 42, in log
2019-01-24 10:29:44.280 Error: EventSystem: domoticz_.log(0, " ".join([str(k) for k in args]))
2019-01-24 10:29:44.280 Error: EventSystem: AttributeError: module 'DomoticzEvents' has no attribute 'log'
import domoticz
