SOLVED: Youless doesn't show gas meter
Posted: Thursday 24 January 2019 10:33
Version: 4.9700
Build Hash: a3a45906
Compile Date: 2018-06-23 16:24:51
dzVents Version: 2.4.6
Python Version: None
Platform: Pi (oldie) / Noobs Raspbian lite
Plugin/Hardware: Youless
Description:
I've installed Domoticz succesfully and got Solar Edge and Youless working. However, the Youless hardware only shows 1 device, for electricity.
It doesn't show the gas meter. Unfortunately that's exactly the one I'm looking for
Anyone any idea why it's not finding the device? Youless firmware is recent, PVOutput version.
Edit: maybe solved: do you really have to add the Youless hardware twice? I just noticed that you can edit the device and I can select gas there.
So I add hardware twice, then for the second device I choose the gas meter?
Hmm. I thought 1 Youless hardware would show 2 devices (just as the Solar Edge did).
Edit2: nope, when I select Gas it just shows the electric values as m3...
Edit3: It's the Youless PVOutput firmware. It doesn't export gas values since PVoutput doesn't work with it (out of the box). I flashed back to default Enelogic firmware and now the gas meter shows up!
Fiddling with SolarEdge/Youless->Domoticz->PVOutput now, impossible to get decent consumption numbers without a seperate kWh meter.
Description:
