Simple socket control not working
Posted: Tuesday 22 January 2019 20:17
First blocky tests are done but can't find reason why it's not working. I have 433 Mhz wall switch and socket, I have reached both and I can control socket from Domoticz software ON and OFF. Also wall switch can be found with Domoticz.
I made simple blocky code than when Switch is ON then set socket ON.
I have also added if else block, where if switch is OFF then socket OFF.
None of these are working.. Do I even need blocky code or can this simple control be done more easily?
So socket should be on only when switch is pressed
