Non permanently connected master / slave system setup
Posted: Sunday 20 January 2019 16:44
I am completely new in Domoticz. I want to evaluate if I could you use Domoticz in the following use case:
I have 5 energy meters (for a local community / VvE) these meters do not have a permanent internet connection. Is it possible that I setup 5 slave raspberry pi with a P1 to USB cable. Having Domoticz installed on every Raspberry PI for local collecting purposes.
Thanks in advance.
- Once a week or month I will walk by with a mobile access point and want the local node sync with a raspberry configured as Masterwhich is somewhere connected to the internet. or ....
- Once a week/month I walk by with an USB stick and sync with the USB stick which in the end syncs with the master device, once plugged in. Or...
- Any other suitable, out of the box solution or direction. Any help / thoughts are welcome.
Thanks in advance.
