dzVents script - Execute setting multiple devices
Posted: Saturday 19 January 2019 21:44
by Rs3b
I'm trying on a specific time set the setpoints of multiple devices at once to a certain value. I notice only the first device is changed after executing the script, the other ones are unchanged. The setpoints are on Popp thermostats.
timer = {
'at 20:55'
execute = function(domoticz)
domoticz.devices('Radiator Setpoint N1').updateSetPoint(12)
domoticz.devices('Radiator Setpoint N2').updateSetPoint(12)
domoticz.devices('Radiator Setpoint N3').updateSetPoint(12)
domoticz.devices('Radiator Setpoint W1').updateSetPoint(12)
domoticz.devices('Radiator Setpoint Z1').updateSetPoint(12)
I also tried using a wild-card, but it doesn't recognize the device this way: domoticz.devices('Radiator Setpoint*').updateSetPoint(12).
As I understand it I cannot use group or scene, because scene is for lights (right?) - at least I do not see the Popp devices when creating group or scene in the add devices dropdown.
Anyone can give me a hint?
Rs3b
Re: dzVents script - Execute setting multiple devices [Solved]
Posted: Sunday 20 January 2019 0:00
by waaren
Rs3b wrote: Saturday 19 January 2019 21:44
Can you try this and look at the log ?
timer = { 'at 23:25' },
logging = {
level = domoticz.LOG_DEBUG,
marker = setSetPoints
execute = function(dz)
local function logWrite(str,level)
dz.log(tostring(str),level or dz.LOG_DEBUG)
local N1 = dz.devices('Radiator Setpoint N1')
local N2 = dz.devices('Radiator Setpoint N2')
local N3 = dz.devices('Radiator Setpoint N3')
local W1 = dz.devices('Radiator Setpoint W1')
local Z1 = dz.devices('Radiator Setpoint Z1')
local setPoints= { N1,N2,N3,W1,Z1}
for i = 1,#setPoints do
setPoints[i].updateSetPoint(12)
local rawData = ""
for j = 1,#setPoints[i].rawData do
rawData = rawData .. setPoints[i].rawData[j] .. "; "
logWrite(setPoints[i].name .. "; type: " .. setPoints[i].deviceType .. "; subtype: " .. setPoints[i].deviceSubType .. "; nvalue: " .. setPoints[i].nValue .. "; rawData: " .. rawData)
Posted: Sunday 20 January 2019 11:41
by Rs3b
Hello waaren,
Many thanks for your example code, it works perfectly!
The log:
2019-01-20 11:17:00.209 Status: dzVents: Info: ------ Start external script: test.lua:, trigger: at 11:17
2019-01-20 11:17:00.229 Status: dzVents: Debug: Processing device-adapter for Radiator Setpoint N1: Thermostat setpoint device adapter
2019-01-20 11:17:00.230 Status: dzVents: Debug: Processing device-adapter for Radiator Setpoint N2: Thermostat setpoint device adapter
2019-01-20 11:17:00.231 Status: dzVents: Debug: Processing device-adapter for Radiator Setpoint N3: Thermostat setpoint device adapter
2019-01-20 11:17:00.231 Status: dzVents: Debug: Processing device-adapter for Radiator Setpoint W1: Thermostat setpoint device adapter
2019-01-20 11:17:00.232 Status: dzVents: Debug: Processing device-adapter for Radiator Setpoint Z1: Thermostat setpoint device adapter
2019-01-20 11:17:00.232 Status: dzVents: Debug: Constructed timed-command: 12
2019-01-20 11:17:00.232 Status: dzVents: Debug: Radiator Setpoint N1; type: Thermostat; subtype: SetPoint; nvalue: 0; rawData: 20.00;
2019-01-20 11:17:00.233 Status: dzVents: Debug: Radiator Setpoint N2; type: Thermostat; subtype: SetPoint; nvalue: 0; rawData: 20.00;
2019-01-20 11:17:00.233 Status: dzVents: Debug: Constructed timed-command: 12
2019-01-20 11:17:00.233 Status: dzVents: Debug: Radiator Setpoint N3; type: Thermostat; subtype: SetPoint; nvalue: 0; rawData: 20.00;
2019-01-20 11:17:00.233 Status: dzVents: Debug: Radiator Setpoint W1; type: Thermostat; subtype: SetPoint; nvalue: 0; rawData: 20.00;
2019-01-20 11:17:00.233 Status: dzVents: Debug: Radiator Setpoint Z1; type: Thermostat; subtype: SetPoint; nvalue: 0; rawData: 20.00;
2019-01-20 11:17:00.233 Status: dzVents: Info: ------ Finished test.lua
It also pointed my to an error in my code, first time I ran the script it got:
2019-01-20 11:04:00.601 Status: dzVents: Debug: Processing device-adapter for Radiator Setpoint N1: Thermostat setpoint device adapter
2019-01-20 11:04:00.601 Status: dzVents: Error (2.4.6): There is no device with that name or id: Radiator Setpoint N2
Turns out I named the setpoint "Radiator Set
Point N2"...I put in a capital P only in this setpoint name. It was the second one in my script, so I tested my original script, and this also ran fine after changing the P into p. Lua is case-sensitive... silly me!!! Still in the learning lua phase...
I may be overasking, but if I want to use domoticz.devices().forEach(..) using an arry, how would the syntax be in that case?
Thanks,
rs3b
Posted: Sunday 20 January 2019 22:40
by waaren
Rs3b wrote: Sunday 20 January 2019 11:41
If I want to use domoticz.devices().forEach(..) using an arry, how would the syntax be in that case?
Thanks,
rs3b
I am not sure what you want/ The example code I posted does iterate over the array of devices.
If your intention is to set the setPoints of all relevant devices in your domoticz environment you could this.
timer = { "every 1 minutes" }
logging = {
level = domoticz.LOG_ERROR,
marker = "filter "
execute = function(dz, item)
spaces = " " ; for i=1,25 do spaces = spaces .. " " end
dz.devices().filter(function(dv) -- Chain filter and forEach
return (dv.deviceType == "Thermostat" and dv.deviceSubType == "SetPoint" )
end).forEach(function(dv)
logWrite((dv.name .. spaces ):sub(1,25) .. dv.setPoint,dz.LOG_FORCE)
-- dv.updateSetPoint(12) -- Setting all setPoints in your system to 12
end)
